I have tried three Flir E4 one by one from a famous online store,
They all work normally when first turning on, but after charging and restart, they all shows problem
The serial number are 63957xxx
Please help to check if your E4 also have this kind of problem!
The following step should reproduce the problem.
1)at room temperature 25degree,
2)turn on the camera and charging the camera for 15 mins with the bundled charger(charging warmup the camera faster than normal usage, for normal usage it may need 30min to reach the temperature for the problem to appear)
3)Turn off the camera,
4)Turn on the camera again and the problem appear.
The condition to reproduce the problem is (1)the camera warmup and (2)after restart.
