Author Topic: The Siglent SDG2042X Thread  (Read 655402 times)
Johnny B Good and 1 Guest are viewing this topic.
Offline Bad_Driver
Re: The Siglent SDG2042X Thread
« Reply #1825 on: July 18, 2024, 05:14:49 am »
Hi Bad_Driver,
Think you are the first to do this!  ;D
You did apply the 50uSec pe amphase, otherwise it sounds very “dull”
Kind regards,
Bram
I know, I know. In the meantime I built a much better Stereo Encoder
https://media.elv.com/file/2001_02_01_se100.pdf
and use a RF-generator for this kind of fun.
Offline KungFuJosh
  • TEAS is real.
« Reply #1826 on: Today at 02:06:48 am »
The screenshot button works!...poorly.
I saved a screenshot today holding down the store/recall button. It saves to the Local drive instead of the USB drive.
That's extra annoying, and there doesn't appear to be any way to change the settings for it. Yes, I also checked the latest manual.
To copy the .bmp file (which should be a .png file) you have to browse to the Local drive, adjust the file types that are visible, then select and copy the .bmp file, then browse to the USB drive, and paste the file. You might also need to change the visible file types again if you want to see what's actually on the USB drive. It's very clunky.
I hope they fix this. When a USB drive is inserted, screenshots should automatically save to the USB drive instead. In general, they should improve the file browsing on these.
Thanks,
Josh
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
The following users thanked this post: Performa01, tautech, Martin72
Offline KungFuJosh
  • TEAS is real.
« Reply #1827 on: Today at 03:02:47 am »
I ran another test with the Reference Out connected directly to the Counter.
Then I took a screenshot. It displayed the confirmation.
Then I went through the tedious process of copying the screenshot from Local to USB.
Viewed it on my PC and this is what was captured:
I went through the whole process again and it captured properly:
« Last Edit: Today at 03:07:11 am by KungFuJosh »
