HiI have a Siglent 2 channel DDS generator, but sometimes I need 3 channelsI have been searching and sofar no hitsAnyone recommend one? (I would like better quality than Aliexpress :-))ThanksKlaus
Yup, almost impossible to find:https://www.amazon.de/-/en/Signal-Generator-Channel-Frequency-Waveform/dp/B089R4NGL9
Quote from: KlausKragelund on April 10, 2022, 09:15:11 amHiI have a Siglent 2 channel DDS generator, but sometimes I need 3 channelsI have been searching and sofar no hitsAnyone recommend one? (I would like better quality than Aliexpress :-))ThanksKlausWhy not getting another one? Do you need 3 channels on the same device?
Quote from: pope on April 10, 2022, 09:41:18 amQuote from: KlausKragelund on April 10, 2022, 09:15:11 amHiI have a Siglent 2 channel DDS generator, but sometimes I need 3 channelsI have been searching and sofar no hitsAnyone recommend one? (I would like better quality than Aliexpress :-))ThanksKlausWhy not getting another one? Do you need 3 channels on the same device?I need to be able to apply 3 phase with 120 degrees between them. Does the Siglent SW support linking them together like that?
Quote from: KlausKragelund on April 10, 2022, 09:47:26 amI need to be able to apply 3 phase with 120 degrees between them. Does the Siglent SW support linking them together like that?The Siglent DDS units have an external trigger input which can be used to start the output.For instance, see page 56 (physical page 67) of:https://siglentna.com/wp-content/uploads/dlm_uploads/2017/10/SDG1000_UserManual_UM02010-E08B.pdf
Quote from: KlausKragelund on April 10, 2022, 09:47:26 amQuote from: pope on April 10, 2022, 09:41:18 amQuote from: KlausKragelund on April 10, 2022, 09:15:11 amHiI have a Siglent 2 channel DDS generator, but sometimes I need 3 channelsI have been searching and sofar no hitsAnyone recommend one? (I would like better quality than Aliexpress :-))ThanksKlausWhy not getting another one? Do you need 3 channels on the same device?I need to be able to apply 3 phase with 120 degrees between them. Does the Siglent SW support linking them together like that?once you have the two phases with 120 degrees between them the last one is just an add and invert
Quote from: langwadt on April 11, 2022, 04:00:54 pmQuote from: KlausKragelund on April 10, 2022, 09:47:26 amQuote from: pope on April 10, 2022, 09:41:18 amQuote from: KlausKragelund on April 10, 2022, 09:15:11 amHiI have a Siglent 2 channel DDS generator, but sometimes I need 3 channelsI have been searching and sofar no hitsAnyone recommend one? (I would like better quality than Aliexpress :-))ThanksKlausWhy not getting another one? Do you need 3 channels on the same device?I need to be able to apply 3 phase with 120 degrees between them. Does the Siglent SW support linking them together like that?once you have the two phases with 120 degrees between them the last one is just an add and invert Yes, but do you have a box like that just handy?Come to think of it, why doesn't anyone sell a box that has amplifiers etc, seems like there could be a marked for it, except for the cheap not sure it works Aliexpress stuff
