Hi all, i'm looking to find a good IGBT tester that will test IGBTs (generally power modules from VFD Drives) that will do high current and high voltage testing. I need to ensure that the IGBTs I buy from china will work when in the drive under load... I know I can make a low current high voltage test and then do high current low voltage which would satisfy (to a point) but I wondered if there are any commercial units out there that anyone's used?
any thoughts?
