Author Topic: Fluke 15B  (Read 7101 times)
Offline ZepnatTopic starter
Fluke 15B
« on: March 29, 2014, 11:05:53 pm »
Hi I've seen the Chinese only market Fluke 15B for a reasonable price but I question the accuracy. As an example the DC range seems rather large variation at +/-1% and 10 counts.
Ignore I used 0.1% instead of 1% in my calculation  :palm:
So if it reads 3.800v the actual value could be between 3.814v or 3.786v
And what if the input voltage is 12.60v is it possible to read between 12.72v and 12.49v please correct me.
I will watch daves multimeter shoot out next week when I can get back onto youtube.
Excuse my ignorance I've never got used to these instruments since they went digital.
AC Current Range : 0.1UA to 10A
DC Current Range : 0.1UA to 10A
AC Range Voltages : 0.1Mv to 1,000V
DC Range Voltages : 0.1Mv to 1,000V
Resistance Range : 0.1 ohm to 40Mohm
Capacitance Range : 0.01nF to 100uF
AC Current : 400uA / 4000uA / 40mA / 400mA / 4A / 10A
 Resolution : +/-1.5%+3
DC Current : 400uA / 4000uA / 40mA / 400mA / 4A / 10A
AC Voltage : 400mV / 4V / 40V / 400V / 1000V
 Resolution : +/-3.0+3
DC Voltage : 400mV / 4V / 40V / 400V / 1000V
 Resolution : +/-1.0+10
Resistance : 400 / 4K / 40K / 400K / 4M / 40M Ohm
 Resolution : +/-0.5%+3
Capacitance : 50nF/ 200Nf / 2Uf / 20Uf / 200Uf / 20Mf
 Resolution : +/-2%+5
It is at banggood for $58
« Last Edit: March 30, 2014, 12:05:51 am by Zepnat »
Offline Fsck
  • sleep deprived
Re: Fluke 15B
« Reply #1 on: March 29, 2014, 11:21:37 pm »
Why do you question the accuracy? The allowable error is large, yes; probably intentional so they don't risk compromising their "rest of the world" lines, and to what they find suitable for the price including their value of brand name.
« Last Edit: March 29, 2014, 11:27:53 pm by Fsck »
"This is a one line proof...if we start sufficiently far to the left."
Offline retiredcaps
Re: Fluke 15B
« Reply #2 on: March 29, 2014, 11:25:35 pm »
The 15B manual states for DCV
0 to 400mV is 1.0% +/- 10 counts (in mV range)
0 to 1000V range is 0.5% + 3 counts (in V range)
For 12.60V, that means
12.60 * .005 = 0.063.
12.60 - 0.063 = 12.537 or 12.54 rounded up.  Now subtract 3 counts.  The lower range is 12.51.
12.60 + 0.063 = 12.663 or 12.66 rounded down.  Now add 3 counts.  The upper range is 12.69.
So for a calibrated reference 12.60, the 15B will be in specifications if the reading is between 12.51 and 12.69.
edit: clarify ranges.
« Last Edit: March 29, 2014, 11:33:29 pm by retiredcaps »
Offline retiredcaps
Re: Fluke 15B
« Reply #3 on: March 29, 2014, 11:29:06 pm »
BTW, Dave talks about counts, accuracy, back in #26
Offline retiredcaps
Re: Fluke 15B
« Reply #4 on: March 29, 2014, 11:41:21 pm »
The specification will be 0.5% + 3 counts for a reading with 3.800V.
3.800 * .005 = 0.019
3.800 - 0.019 = 3.781.  Subtract 3 counts. 3.781 - 0.003 = 3.778
3.800 + 0.019 = 3.819.  Add 3 counts. 3.819 + 0.003 = 3.822.
« Last Edit: March 29, 2014, 11:42:52 pm by retiredcaps »
Re: Fluke 15B
« Reply #5 on: March 30, 2014, 12:01:38 am »
ahh ha...
Thank you all for your fast replies I now see where I went wrong, using the specs from the sellers website they quote
1.0% +/- 10 counts,
they don't mention;
Also I used 0.1% in the initial calculation instead of 1% im a idiot my bad.
Ill watch that video next week, no youtube at the moment due to internet provider not liking me watching daves long videos!
Think I might get one here is the link if anyone else interested
http://www.banggood.com/Fluke-15B-F15B-Professional-Auto-Range-Digital-Multimeter-Tester-p-911684.html
They are ok I have bought from them before.
Offline Fsck
  • sleep deprived
Re: Fluke 15B
« Reply #6 on: March 30, 2014, 12:04:09 am »
for that price, wouldn't a UT-61E be a better choice (for electronics)?
you'd get superior specs and computer logging.
Offline Lightages
  • Canadian po
Re: Fluke 15B
« Reply #7 on: March 30, 2014, 12:18:57 am »
The Fluke is 15B is not the fullest featured multimeter in the world but you can count on its build quality and it being safe. That is the trade off compared to the UT61E and its higher accuracy and computer logging.
Offline Fsck
  • sleep deprived
Re: Fluke 15B
« Reply #8 on: March 30, 2014, 12:24:55 am »
but, it's safeness rating is still limited, but still above what typical electronics fall under.
Re: Fluke 15B
« Reply #9 on: March 30, 2014, 12:31:10 am »
Certainly looks like it would be thanks.
Is the UT-61E accurate enough to make use of the extra display resolution,  having the extra digit only gives a more meaningful result if its reliable right?
Do like the data logging option and for under $50 bargain!
Offline Fsck
  • sleep deprived
Re: Fluke 15B
« Reply #10 on: March 30, 2014, 12:37:19 am »
large thread on it:   https://www.eevblog.com/forum/testgear/uni-t-ut61e-multimeter-teardown-photos/
there are many threads about it, due it's excellent performance+features/cost ratio.
Re: Fluke 15B
« Reply #11 on: May 08, 2014, 10:30:48 pm »
So, I opted for the ut-61e from a seller off aliexpress. £29 well spent. The ohms range is lightening fast also the bar graph is more useful than expected. Downloaded ultra dmm but not used in anger yet..
Happy  8)
Offline miguelvp
Re: Fluke 15B
« Reply #12 on: May 10, 2014, 07:30:21 am »
Happy  8)
Try http://sigrok.org/
They seem to support your meter: http://sigrok.org/wiki/UNI-T_UT61E
