Greetings, This is the second time for this posting. Apparently the gentleman that originally wanted it changed his mind. Here is the deal .. A friend of a friend of mine has an old HP 524A counter he wants to disposeof. It is HP's first counter made back in the 50's. Many years ago it wasworking but has sat in a dry garage ever since and may or may not stillwork. It weighs about 80 lb and has a zillion tubes and has an ovenizedxtal. It is located in Los Altos CA and due to size and weight is pick up only.If no takers it will unfortunately go to the trash. http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1951-01.pdfhttp://www.cs.ubc.ca/~hilpert/e/edte/HP520/Let me know if you know of anyone interested in this piece.Dick
