Loading [MathJax]/extensions/Safe.js
Author Topic: 163 A - 400 Hz CT Testing For Aviation Generator Application  (Read 1804 times)
Offline SteveRTopic starter
« on: November 28, 2023, 09:16:48 pm »
Hi All,
What power supply equipment could I use to provide a 400 Hz, 163 A rms supply to support the testing of a wound Current Transformer installed to an aircraft power generator?
The test requirements are as follows:
"The assembly should provide a voltage of 3.45 as measured across a 10 ohm, 3 watt burden resistor, when a single turn primary current of 163amps rms 400Hz is flowing."
Thanks in advance for your inputs!
Offline bdunham7
Re: 163 A - 400 Hz CT Testing For Aviation Generator Application
« Reply #1 on: November 28, 2023, 09:30:27 pm »
You could use two Fluke 52120A transconductance amplifiers in parallel driven closed-loop by a Fluke 5730A calibrator.  Or they can be driven open-loop by any calibrator with the result of a little less accuracy.  If you need this level of accuracy, then it won't be cheap.  What level of accuracy do you actually need here?
Offline rvalente
  • Country: br
« Reply #2 on: November 28, 2023, 09:35:59 pm »
Check chroma and itest AC power supply, they often go up to 1KHz.
Maybe... using a big ass AB 10KW audio amplifier with an external current loop?
« Reply #3 on: November 28, 2023, 09:45:42 pm »
Many thanks for your reply, full requirements with tolerances attached.
Offline rvalente
  • Country: br
« Reply #4 on: November 28, 2023, 11:08:11 pm »
Hi All,
Probably these specs was written in the time where big electrical machines were used. I'd says its a suggestion for a GPU (ground power unit) + transformer.
Offline floobydust
« Reply #5 on: November 28, 2023, 11:38:26 pm »
You can spoof the high current to test CT's.
I'll take a mains power transformer like MOT or big toroid and put a few turns of heavy wire on it like #6 or #4AWG to make a low voltage secondary. What you need is around 2VAC at say 200A (~400VA). Then run that through the CT under test.
The primary could be energized by 50/60Hz and 400Hz with a Chroma to see if the burden resistor etc. is reasonable for meeting the spec. Watch the CT's phase might be important too for the protection module.
Online TurboTom
« Reply #6 on: November 29, 2023, 06:06:39 pm »
if the current transformer is to be tested separately and the single high current (primary) conductor can be removed, you could put a test winding there with 163 turns and just feed in a current of 1A which should be easily possible with an average audio amp.
Otherwise, my approach would be making a step-down transformer with approximately a 163:1 turn ratio on a decently large, low-loss core and some copper sheet metal as the single or two turn secondary. A clamp type current meter should do for checking the test current is within tolerance.
