Author Topic: 1500$ Budget ,I need your eperience  (Read 4588 times)
Offline eevblogfanTopic starter
« on: June 17, 2013, 06:01:00 pm »
hey
I want to learn more into the linear part of things  - But integrate the Digital world as well
so far I am stuck with DC electronic load , due to the neglegible time I had to work on that project plus budget limits  ,
I'd like to ear from you what sort of project you can offer me to do , In order to cover the biggest range of experience , be sure I'll have fun from any project :P
I thought of building from scratch linear power supply , but having some hard to get specs , such as 100uV load regulation ( range lower then 100mA )
recovery time >10uS ( is it possible ? )
please don't dear to yell at me for the rubbish I wrote above , that said without even think of any limitations , really  :-+
the instrument I have (so far)
Fluke PM2813
E3610A
2X HP3478A
HP34401A
Agilent DSOX2002
Old(ish) Kenwood 40Mhz scope
fluke 87V
fluke 287
HP3366B
Hakko-fx888 ( I don't like the small thermal capacity , it's integral part of me  )  may I jump up to ersa some day ? , well I hope to open thread about that .
and I have got for now IET "High power" resistance box , 7 Decades . 1Ohm to 10Mohm , 0.1% , it's in my lab for repair , I might buy it for cheap .
I am pretty sure the only instrument I miss is good electronic load ( to cover my stupide non stopping  mistakes )
no need for super high power , 10W 0~1mA should do , I already got 0.1% 100OHm resistors , I'll do something soon ( 0~1mA is good for any logics , perhaps another range for 10mA and above )
and of course the fastest respon?e I can achieve , the better ( I think )
with 1500$ , what is the most important things to have ?
and please add links to ebay actions or products you'll be reffering to , and don't forget price :)
things to buy :
capacitors assortment ( I cant find where from :( )
comperhensive resistance assortment , I think of getting 1/4W and perhaps jump to 1/2W or 1W . E12 should do right ?
cabinets , lots of them :P
maybe few accessories , no more then 100$ ( grabbers . BNC stuff , etc ... )
few soldering boards .. different sizes
and I can't think clearly at that moment , please help me here :P
thank you
Yuval
Offline c4757p
  • adieu
Re: 1500$ Budget ,I need your eperience
« Reply #1 on: June 17, 2013, 06:12:28 pm »
Sounds like you've got an idea right there! What do you need ours for?
Yes, those specs are possible, though tricky. (I'm going to assume you meant recovery time < 10us).
S = siemens. s = second.
« Reply #2 on: June 17, 2013, 06:23:30 pm »
Hey c4757p :)
specs should serve some purpose right ?  well the only spec I can use here is that >10us recovery , >100uV load regulation is good for low power high accuracy stuff , but I plan on getting Fluke 5100A for cheapie , so I assume he will fit thaht need . although , the meaning of these specs from beginning was to challenge me , hence I am open to that idea  ::)
as for reference , I have got some 5V 20ppm/C onese , But I might dear using Lm399's  :bullshit:
apart from nice power supply , is there any other Idea ? and please feel free to give me hard ones :P
thank you :)
Yuval
« Reply #3 on: June 17, 2013, 07:29:20 pm »
hey
http://www.ebay.com/itm/Agilent-MSO6012A-Mixed-Signal-Oscilloscope-8ML-/190806934357?pt=BI_Oscilloscopes&hash=item2c6cfac355
out of curiosity , is that scope worth trading my DSOX2002 for ?
tell you the truth , no need for any logic analyzer yet , as for BW , the bigger the better :P
thank you
Yuval
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #4 on: June 17, 2013, 07:42:46 pm »
Do you want to learn about electronics, or collect test gear?
« Reply #5 on: June 17, 2013, 07:47:10 pm »
since I have already the DSO , trading gear is fine , if added money was including , well I suspect my answer was 90% learn and 10% collect  :clap:
Offline smashedProton
« Reply #6 on: June 17, 2013, 08:11:28 pm »
You may want to do what I did.  Go to electronic goldmine and buy every assortment they have.  Go and get some cheap plastic tool bins.  Get a giant ass breadboard.  Make sure you have plenty of all the jellybean components.  That means a ton of 7400 logic.  At this point in your career, more ttl less vhdl.  The psu idea sounds great.  Just to add to the fun, I will add a digital interface programmed with a soldering
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
« Reply #7 on: June 17, 2013, 08:12:58 pm »
Right now my fun gen is a guitar.. :palm:
« Reply #8 on: June 17, 2013, 08:19:45 pm »
hey smashedProton
I am really sorry if I got you wrong ,  Did you talked sarcastic?
Digital interface to that ? , nope , I already got 2 proggramable supplies and besides that fact , I really like old linear touch , 10 Turn pots are fare more superior in my mind , almost any cheap/not tide ass costy . Digital interface is bad to my thinking
you are absolutly right after I'll build the linear supply , That will gonna be nice challenge to fit that Digital control firstly , and attempting to cause it to feel as good as I can to my feel ( for example , that encoders , with two ranges , and speed detect stuff , allows 1mV resolution and some course steps with either speeding up or pressing the knob )
« Reply #9 on: June 17, 2013, 08:25:14 pm »
I agree that digital interfaces are a bit fiddly.  I meant a diy digital ammeter and voltmeter for the supply.  The control would still be analog.
Offline Smokey
  • Not An Expert
« Reply #10 on: June 17, 2013, 09:50:18 pm »
Build a mostly discrete audio power amplifier.  That's a full analog smack to the face, but you can build it up one block at a time as you learn what all the sub-circuits do.  You get a bit of everything in the design, including a really cool system you can show off to all your friends at the end (assuming you get it working).  And you don't need to spend 1500 bucks to do it since you have a ton of gear already.
Check out:
http://www.amazon.com/Designing-Audio-Power-Amplifiers-Cordell/dp/007164024X/ref=sr_1_1?s=books&ie=UTF8&qid=1371505403&sr=1-1&keywords=audio+power+amplifiers
and
http://www.amazon.com/High-Power-Audio-Amplifier-Construction-Manual/dp/0071341196/ref=sr_1_3?s=books&ie=UTF8&qid=1371505403&sr=1-3&keywords=audio+power+amplifiers
Both books have a good mix of theory and actual circuits with the second, Slone's book, having more actual working schematics for various amps.  It even has the PCB layouts if you want to cheat and use one of his designs.
« Reply #11 on: June 18, 2013, 04:47:04 pm »
Hey thanks
I might start to love Audio , but at the moment I am looking for control loops and stuff to that content :P
Offline Paul Price
« Reply #12 on: June 18, 2013, 06:33:16 pm »
If you want to fine a nice project to work one consider this:
Necessity if the Mother of Invention.
Search your imagination to decide on some simple or even complex device that might seem to help you learn about something your are interested in, or something that is  very interesting or very fun and playful or even something that might do something that is practical and innovative or just a little helpful to you or others.
Offline madshaman
  • ego trans insani
« Reply #13 on: June 18, 2013, 08:15:41 pm »
I second that you choose something you have a need for.
Barring that, the linear supply is a *great* idea, you'll learn the basics of a control loop plus all the fiddly bits and your 40Mhz scope should catch any oscillations if you choose slower (for DC applications) opamps and power devices.
Something more ambitious would be a switch-mode AC-DC supply or DC-DC converter that operates in the tens of kilohertz maybe?  Based around a cuk converter so you can dial in any voltage you like?
I'd actually shy away from an audio amplifier, even a simple class A.  Opinions may very but audio amps are fairly involved (well, like power conversion isn't), that's my two cents.
« Last Edit: June 18, 2013, 08:17:18 pm by madshaman »
To be responsible, but never to let fear stop the imagination.
