Author Topic: BK Precision 1901B on/off  (Read 144 times)
Offline FrankBussTopic starter
    • Frank Buss
« on: July 02, 2024, 11:27:16 pm »
I bought a BK Precision 1901B, and looks like it works, but why doesn't it have a soft power on/off button as many other power supplies? I guess my fault for not reading the manual carefully.
But looks like it is possible with the remote DIN connector. Thinking about to open it and drill a hole in the front for a button, but this might be a problem for warranty in case it breaks someday. Anyone who has a 190x? How did you solve this problem?
There is also an USB input, haven't looked into it so far, maybe I can control it from PC?
Offline slugrustle
Re: BK Precision 1901B on/off
« Reply #1 on: July 03, 2024, 12:58:14 am »
Check out section 5.1.4, "Enable and Disable the Output" in the manual.
For USB, check out the programming manual and associated control software.
Docs and Software tab at https://www.bkprecision.com/products/power-supplies/1901B
    • Frank Buss
« Reply #2 on: July 03, 2024, 02:17:31 am »
Yes, I've read this, and I can build something, and probably glue a button on top to avoid problems with the warranty. Was just wondering why they didn't spend one dollar for an extra button for an 800 dollar power supply, and how others solved it.
I could also feed it to an electronic load I have, which has a button  :)
