Author Topic: 121GW included thermocouple maximum operating temperature?  (Read 1595 times)
Offline rs20Topic starter
« on: August 23, 2018, 01:23:13 am »
I'm wondering what temperature I can safely operate the included thermocouple at? The 121GW manual states that it can measure up to 1350 degrees C, but I think that's talking about the range the multimeter is capable of understanding, not the temperature that the specific supplied thermocouple's insulating sleeve can withstand.
Does anyone know what the model number and/or operating temperature range of the supplied thermocouple is?
Offline Miti
Re: 121GW included thermocouple maximum operating temperature?
« Reply #1 on: August 23, 2018, 01:48:09 am »
Usually they are K type. Check for a K on the connector.
Edit: Yes, K type, it says in the manual. And yes, K type can withstand 1350C.
« Last Edit: August 23, 2018, 01:54:10 am by Miti »
Fear does not stop death, it stops life.
Offline DaJMasta
    • medpants.com
« Reply #2 on: August 23, 2018, 02:41:09 am »
Maybe the thermocouple metal itself, but I doubt the insulator around it can stand up to that.
Offline Seppy
  • Curious
« Reply #3 on: August 23, 2018, 04:30:20 am »
I contacted Kane and they said it will measure up to 1350 degrees.
« Reply #4 on: August 23, 2018, 05:00:18 am »
Wow, really? Are you sure they're not making the same mistake as Miti? What is the insulation made of, glass fibre?
Offline radhaz
« Reply #5 on: August 23, 2018, 05:28:06 am »
https://en.wikipedia.org/wiki/Thermocouple#Table_of_insulation_materials
Organic insulation won't even come close to surviving 1350 °C. Mineral Insulation.
« Last Edit: August 23, 2018, 05:49:53 am by radhaz »
The following users thanked this post: rs20
« Reply #6 on: August 23, 2018, 07:51:35 am »
Seppy, can you please go back to the manufacturer? I simply cannot believe the insulation on this thrown-in-the-box thermocouple has a higher thermal tolerance than even the most exotic materials listed here: https://en.wikipedia.org/wiki/Thermocouple#Table_of_insulation_materials
Offline Seppy
  • Curious
« Reply #7 on: August 24, 2018, 12:31:24 am »
Done, we will see... I agree, I don't know how that is a thing, I've asked what the insulation is.
