But that is a problem with some of the earlier BG7TBL units and not a GPDSO in general. AFAIK this has been fixed in later units and either way the absolute accuracy is likely to be better than the freerunning Rubidium clock.
I never wrote that it was a problem with every GPSDO. I only pointed out that you don't necessarily have an accurate 10MHz just because you have a GPSDO.
Btw, I don't think "freerunning" and "not accurate at all" are correct attributes to give a rubidium standard.
I have tried to compare my sa.22c to my Star 4.
Attempt 1: Frequency difference between A & B using Pendulum CNT90. Noise centered on 0.
Attempt 2: Time from A to B using Pendulum CNT90. Expected slow sawtooth but found noise.
Attempt 3: Display signals on oscilloscope. Observed two static sine waves. Phase shifted but stationary. Got bored after an hour.
The Sa.22c do have a PPS input for automatic adjustment, but I have not used it.
