I have tested the accuracy (see some posts above) against a Miller GPSDO and it was within 0.001Hz.
I have also tested the OFFSET function and that changed the output accordingly (see some posts above). I used -0.3Hz. There is however a bug for negative offsets stored, and I do not really use it since I want 10MHz output exactly. I believe the OFFSET should be saved -after- PWMSET is saved. There is no mention of OFFSET in the manual whatsoever.
The PWMSET value after correctly saving, so dial to PWMSET, push the knob, dial to EXIT, push the knob, works and the value is stored. This is however for use after power up without the antenna, so as a "normal" XO. Then this value is used a reference. Once you reconnect the antenna, the GPSDO starts to align the PWMSET again. This is described in the manual (which I posted above).
Above all applicable to the stock firmware.
