The PPb / PWM menu starts after powering up with a connected antenna after PPS on the ATGM 336H-5N-31 starts blinking in Red (1Hz). This means the unit receives GPS/Beidu information from the satellites. This may take some time and the antenna position must be ok to receive signal but for my unit it starts very quickly.
If no satellites found, the unit stays on the "10.00Mhz / GPSDO" main screen.
The PWM adjusts the 1 unit PWM = 0,000076 V adjustment voltage to the OCXO. Saving needs to be done so that the next time the unit starts it goes more quickly to 10MHz output.
