Author Topic: 100:1 probe for measuring ripple in a tube amp power supply  (Read 12160 times)
Offline David Hess
  • DavidH
Re: 100:1 probe for measuring ripple in a tube amp power supply
« Reply #75 on: December 21, 2022, 05:26:50 pm »
High voltage x100 probes with 10 to 50 megohm input resistance indicating a shunt resistabance to attenuate the DC voltage still exist, at least in theory, but they cost almost $1000 now.  I think Testec used to have a lower cost one but apparently no more.
Offline vk6zgo
« Reply #76 on: December 21, 2022, 11:29:41 pm »
The only time I've needed a x100 probe was as a "cheap & nasty" substitute for an active probe, back when such devices were prohibitively costly.
They were, of course, conventional ones, but the signal I was looking at required a device with around 100 M input impedance, & was of fairly high level, so it was (just) adequate.
Offline tautech
« Reply #77 on: December 22, 2022, 12:15:07 am »
Yes, an often overlooked advantage of the 100x probe is the low input capacitance, often well under 5pf.
Offline floobydust
« Reply #78 on: December 25, 2022, 11:38:23 pm »
This looked reasonable, without the danger of AC-coupling being a problem.
Offline David Hess
  • DavidH
« Reply #79 on: December 26, 2022, 01:35:31 am »
That is basically the P6009 schematic, shown below.  It takes a little more than the bare essentially to get 100+ MHz performance.
« Last Edit: December 26, 2022, 01:37:37 am by David Hess »
