Author Topic: 1000X Tektronix P6015A Probe ID  (Read 629 times)
Offline jonpaulTopic starter
« on: March 03, 2020, 10:23:36 am »
Bonjour a tous:
Testing several Tek P6015A 1000X HV probes, with modern scopes that have the sensing of the probe faxtor.
Discovered on 2465/7/B the P6015A will not work, every unit (tested 4 scopes and 2 probes gives ID, as if the probe ID button is pushed.
They do NOT give a proper trace, and the scale factor reading stays on ID.
Anyone ever try this? Seems undocumented.
Only fix seems to be to isolate the probe ID pin   from the scope BNC
Mille mercis.
Jean-Paul
Jean-Paul  the Internet Dinosaur
