Author Topic: 0.7x Barlow Lens for this Stereo Microscope possible?  (Read 452 times)
Offline dreddTopic starter
« on: June 06, 2024, 04:08:27 am »
Hi.
I needed stereo microscope for soldering work, and got this used one:
2284839-0  2284843-1  2284847-2  2284853-3
It has WF10X eyepieces and switchable 2X and 4X objective, you rotate it 180deg to select.
Now I read everywhere that I'm better off with 0.5x or 0.7x Barlow Lens at the bottom, to reduce magnification and increase working distance. Most common barlow lenses have 48mm diameter screw-on threads.
But this scope has no threads at bottom, see "Pic 1", was a bit of disappointment.
What do I do? Much appreciated!
« Last Edit: June 06, 2024, 01:05:47 pm by dredd »
Offline jfiresto
Re: 0.7x Barlow Lens for this Stereo Microscope possible?
« Reply #1 on: June 06, 2024, 05:07:08 pm »
That looks to me like a typical, 10X/20X dissecting microscope. Here, is an ad for the one I have, I bought for cheap to learn on, that shows a typical use and user:
(Looking at her hands and makeup, I would say that is an older model posing as a high school student.)
I expect you belong to a different demographic that needs a different microscope, a "routine, system microscope", which you can add to or change – for example, with different stands, eyepieces, barlow lenses, and so on – to address a wide range of applications.
« Last Edit: June 06, 2024, 05:12:09 pm by jfiresto »
-John
« Reply #2 on: June 07, 2024, 05:50:41 am »
Yes, typical stereo scope, I'm not in position to buy new AmScope, but I want AmScope :)
It seems I have the solution, I bought this 0.3X Barlow lens on Aliexpress with 42mm thread, that I will jam somehow into the bottom of the black plastic conical housing I have, which is 40mm inside diameter at the bottom.
https://www.aliexpress.com/item/1005004924531709.html
AmScope SM-3 Manual  * SM-3_Manual_151001.pdf  has same barlow lens arrangement (see page 15), which gives me hope.
This will reduce magnification from 20x,40x to 7x,14x with increased working distance. Now I need boom-arm stand lol
« Last Edit: June 07, 2024, 06:47:15 am by dredd »
Offline jfiresto
« Reply #3 on: June 07, 2024, 06:13:41 am »
That often gives not half bad results because of the low numerical aperture of the barlow lens.
Rather than jam, you could glue to the conical housing, a 42mm  to something-at-least-as-big camera thread adapter and then be able to add or remove the lens or other accessories. What is the plastic?
« Last Edit: June 07, 2024, 06:15:36 am by jfiresto »
-John
« Reply #4 on: June 07, 2024, 06:26:02 am »
Some plasticky feeling hard plastic :) Maybe has carbon fibers in it.
Yea, I heed to find something bigger with inner 42mm thread, it feels like a challenge...
« Reply #5 on: June 07, 2024, 08:17:28 am »
Look at ~40mm PVC waste pipe and you might know someone local that can spin it to size for just a simple firm press fit.
