Author Topic: Agilent E7495A software  (Read 1432 times)
Offline krullsTopic starter
« on: March 07, 2019, 03:13:57 pm »
Does anyone have access to the E7495A Performance Verification and Adjustment software that's called out in the service manual? Seems that's the only way to make adjustments. Keysight says it's not available but they will calibrate the unit for $600, more than twice what I paid for it.
TIA
Steve
Online PA0PBZ
Re: Agilent E7495A software
« Reply #1 on: March 07, 2019, 03:33:09 pm »
The problem with that software is that you need a very specific list of test equipment that is going to be controlled by GPIB from the PC running the test software, so it is not of much use if you don't have the equipment. Having said that, here you can download the software and have a look (needs a license key)
http://cal.software.keysight.com/
Also, read this:
https://www.keysight.com/upload/cmc_upload/All/TMETutorial_E_02_11.pdf
