Author Topic: Fluke 177 failed and need support to repair  (Read 3994 times)
Offline ChinhdcTopic starter
  • Country: vn
Re: Fluke 177 failed and need support to repair
« Reply #25 on: December 30, 2021, 03:04:51 pm »
I found that model 177 has a 6-leads SOT-23 with name LPTZ, follow you guide, i check the pin 6 to COM, it's on a rail; then measure the impendance of pin1 (GND) - Pin4 (Vin) is high ~ 5MOhm; pin 1 - Pin 6 (Vout) ~ 30KOhm (infact the impendance is not stable at a value, it varies). So, it's the sign of defect the LPTZ component?
 Looking forwards your early tip to bring it back normally.
  • Country: vn
« Reply #26 on: December 30, 2021, 03:11:18 pm »
and, i measure in Voltage the LPTZ component (Battery>9VDC):
- Pin1-Pin4: 4.92V
-Pin1-Pin6:2,475V
So, is any guy have a tip for me about this?
Offline bdunham7
« Reply #27 on: December 30, 2021, 03:39:24 pm »
- Pin1-Pin4: 4.92V
-Pin1-Pin6:2,475V
It looks like the power supplies are good.  The IC marked 'PCY' right below the LPTZ is your 5.0V regulator, I don't see the 3.3V regulator if there even is one.  Look elsewhere for a similar sized IC with the markings 'AQI'.  If your power supplies are good, I don't have any other hot tips for troubleshooting this.
Offline andyB2022
« Reply #28 on: July 15, 2022, 09:50:02 am »
Hi, I have the same issue. @Chinhdc did you manage to solve the issue?
  • Country: vn
« Reply #29 on: July 25, 2022, 02:47:07 pm »
not yet, the meter is still in the store :((
