Dear all
The tester doesn't turn not. When I press the rotary button the LCD lits and as soon as I release the button it turns off.
I tried to reprogram the chip using the files from mega328_st7565_kit (the last ones on the site).
TransistorTester.eep dated 4/21/2016
TransistorTester.hex dated 7/9/2016
but I do not know it it was success or not here is my result.
C:\AVR>avrdude -c usbasp -p m328p -F -B 4.0 -e -U flash:w:"TransistorTester.hex"
:i -U eeprom:w:"TransistorTester.eep":i -U lfuse:w:0xF7:m -U hfuse:w:0xD9:m -U e
fuse:w:0x04:m
avrdude: set SCK frequency to 187500 Hz
avrdude: warning: cannot set sck period. please check for usbasp firmware update
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: erasing chip
avrdude: reading input file "TransistorTester.hex"
avrdude: writing flash (29952 bytes):
Writing | ################################################## | 100% 20.10s
avrdude: 29952 bytes of flash written
avrdude: verifying flash memory against TransistorTester.hex:
avrdude: load data flash data from input file TransistorTester.hex:
avrdude: input file TransistorTester.hex contains 29952 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 15.55s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x00 != 0x2d
avrdude: verification error; content mismatch
avrdude: safemode: lfuse changed! Was f7, and is now 8c
Would you like this fuse to be changed back? [y/n] n
avrdude: safemode: hfuse changed! Was df, and is now 0
avrdude: safemode: efuse changed! Was 1, and is now 6
avrdude: safemode: Fuses OK (E:01, HF, L:F7)
avrdude done. Thank you.
I got a spare blank chip. do you think I should try with that one? In case it doesn't work will I be able to reprogram my spare for use with arduino?
I'm sorry to be this cheap but where I live those chips are not easy to come by and bringing them in here is expensive.
Thank you all for your help
Belen
