Author Topic: $20 LCR ESR Transistor checker project  (Read 3910333 times)
Phil1977 and 31 Guests are viewing this topic.
Offline mauroh
    • Mauro Pintus
« Reply #2076 on: June 13, 2016, 10:19:51 pm »
Thanks  :-+  I corrected my previous post  :)
Mauro
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #2077 on: June 14, 2016, 12:16:41 am »
Interesting information. I may be able to do this.
I like the way you added the header to the device for programming also. Could do it on the bread board but have to locate the missing 8MHz crystals I ordered  :palm:
Offline ogara
« Reply #2078 on: June 14, 2016, 10:20:41 am »
I bought a LCR T4 Mtester last year, graphic display, yellow PCB but only started on it now.  It starts up with only Mtester logo msg, no other version or model numbers visible.
Did a upgrade apparently without issue, need only to change to "CFLAGS += -DLCD_ST7565_V_FLIP=1".  This is from the "transistortester-master\Software\trunk\mega328_st7565_kit\Makefile", which I understand is the "K" firmware.
I also try to upgrade to the "M" trendy firmware specifically 'ComponentTester-trendy-1.22m' but only ended up with a blank display.  Did tried playing with the obvious settings in the config.h but no luck getting the right combo.  I find its settings layout more daunting but is my tester even compatible with m-firmware?
Offline madires
  • A qualified hobbyist ;)
« Reply #2079 on: June 14, 2016, 11:03:25 am »
Yes, ST7565 is supported by the m-firmware:
 *  Chinese clone T3/T4 with ST7565 display
 *  - thanks to tom666 @ EEVblog forum
//#if 0
#define LCD_ST7565R_SPI
#define LCD_GRAPHIC                     /* monochrome graphic display */
#define LCD_PORT         PORTD          /* port data register */
#define LCD_DDR          DDRD           /* port data direction register */
#define LCD_RESET        PD4            /* port pin used for /RES */
#define LCD_A0           PD3            /* port pin used for A0 */
#define LCD_SCL          PD2            /* port pin used for SCL */
#define LCD_SI           PD1            /* port pin used for SI (LCD's data input) */
#define LCD_CS           PD5            /* port pin used for /CS1 (optional) */
#define LCD_DOTS_X       128            /* number of horizontal dots */
#define LCD_DOTS_Y       64             /* number of vertical dots */
#define LCD_START_Y      0              /* start line (0-63) */
#define LCD_CONTRAST     11             /* default contrast (0-63) */
#define FONT_8X8_V                      /* 8x8 font, vertically aligned */
#define SYMBOLS_24X24_V                 /* 24x24 symbols, vertically aligned */
//#endif
If you need to flip the y direction:
#define LCD_FLIP_Y                      /* enable vertical flip */
And if you got a small x offset enable or disable:
#define LCD_OFFSET_X                    /* enable x offset of 4 dots */
Offline ogara
« Reply #2080 on: June 14, 2016, 12:04:33 pm »
Thanks, I tried again, enabling/disabling all 3 ST7565 section with LCD_FLIP_Y but still no display .  Any other switches I can try?  I have also tried changing the contrast numbers around.
« Last Edit: June 14, 2016, 12:06:34 pm by ogara »
Offline madires
« Reply #2081 on: June 14, 2016, 12:23:01 pm »
Is the LED lit when the tester is powered on? Rotary encoder?
Offline ogara
« Reply #2082 on: June 14, 2016, 01:03:58 pm »
It doesn't have a led but the LCD backlight does come on for some seconds and no addons yet, still factory default.
Offline madires
« Reply #2083 on: June 14, 2016, 01:58:16 pm »
And you've also updated the EEPROM?
Offline ogara
« Reply #2084 on: June 14, 2016, 03:01:58 pm »
Yes both ComponentTester.hex & ComponentTester.eep, using a batch file to flash to avoid mistakes.
Offline vinceroger
« Reply #2085 on: June 14, 2016, 07:30:17 pm »
Hi i new too this site just came across it whilst searching for some build instructions for this tester i have just brought can anyone help with a link etc many thanks in advance
http://www.ebay.co.uk/itm/331873741389?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
just had a thought are the resistor values etc marked on the pcb already? i usually buy this type of tester pre built but thought i would have a go at building a kit form one.
« Last Edit: June 14, 2016, 09:23:20 pm by vinceroger »
Offline bitseeker
« Reply #2086 on: June 14, 2016, 09:24:28 pm »
Welcome to the forums, vinceroger.
The PCB has all the parts identified on it. So, build instructions generally aren't needed. Here are some tips:
1. Put the lowest components on first (e.g., resistors) and work your way up (IC sockets, capacitors, transistors, connectors).
2. Before installing the microcontroller and screen, power up the tester and verify the voltages on the IC socket and LCD connector. This is your only opportunity to make sure that you won't fry anything.
3. Once everything is working, be sure to calibrate it. Your kit may include an extra capacitor for this purpose.
The listing below has a photo of the assembled PCB without the screen that might be useful for reference:
http://www.ebay.com/itm/272165236396
Offline timofonic
  • Eternal Wannabe Geek
« Reply #2087 on: June 14, 2016, 10:10:17 pm »
@c4757p
@madires
What about the madires' feedback? Is an interesting project and he might provide some interesting feedback.
Even better: If submitted to GitHub, many people would fork or and provide interesting modifications.
It's a popular product /project too, a cool "Made with KiCad" logo in the schematics and PCB would be interesting too!
Offline madires
« Reply #2088 on: June 15, 2016, 10:50:13 am »
Still no output at all? That's strange! Maybe some 5V<->3.3V issue with the display? The mega328_st7565_kit's Makefile has LCD_SPI_OPEN_COL disabled. So it must be something else. Unfortunately I don't got that T4 clone. If the manufacturers would send me their clones it would make things much easier.
Offline vinceroger
« Reply #2089 on: June 17, 2016, 09:41:24 am »
Well the kit has just arrived the bad news is the pcb has none of  the parts identified on it bacically its mark r1 r2 c1 c2 etc no instructions either in the package and the seller hasnt got any either i will try to upload a picture later but without knowing what value resitor/capacitor etc goes where im a bit stuck.
Offline madires
« Reply #2090 on: June 17, 2016, 11:31:19 am »
The transistor tester's circuit is fairly simple and the clones are all based on the basic circuit in Karl-Heinz' doumentation. Please see https://github.com/svn2github/transistortester/blob/master/Doku/trunk/pdftex/english/ttester.pdf for the circuit. Why don't the sellers just put a note with the project's URL into the bag?  :-//
Offline bitseeker
« Reply #2091 on: June 17, 2016, 03:36:32 pm »
Unfortunately, most of the sellers that carry the various testers based on the original design know little to nothing about them. So, I doubt they'd even know where to get a link to the project and its documentation.
@vinceroger: Sorry to hear that the silkscreen on the model you received was so sparse. As madires said, you'll be able to refer to the original schematics to identify which component fits where. There isn't a huge variety of components, which makes the task less daunting than it might at first appear to be.
Take a photo of the bare board (both sides) before you begin. If you get stuck, you can post your questions and the pic here. After you've finished building and testing it, if you're so inclined, it'd be great if you could post an updated version of the photo with the component values inserted. :-+
Offline ogara
« Reply #2092 on: June 17, 2016, 03:56:38 pm »
It works now, my bad, I must have set and left the contrast higher while editing the config.h file.  The (M12864 DIY Transistor Tester) section with LCD_FLIP_Y disabled works best.
Offline vinceroger
« Reply #2093 on: June 17, 2016, 04:41:15 pm »
Im just measuring all the resistor values in the kit and also seeing what the four transistor part numbers are the rest i have already figured out.
« Last Edit: June 17, 2016, 04:48:20 pm by vinceroger »
Offline bitseeker
« Reply #2094 on: June 17, 2016, 04:54:00 pm »
That's great. You're quick. By the way, what speed crystal did they use on that model? 8 or 16 MHz?
Offline vinceroger
« Reply #2095 on: June 17, 2016, 05:02:12 pm »
its a 8 mhz crystal
transistors are 2x c945 p331 1x 4673 4c gf 2 1x ws tl431 928
resistors x6 10k   x2 1k   x2 27k    x3 470k    x1 470 ohm   1x 33k  x3 680 ohm   x1 100k  x1 560 ohm  x2 3.3k   x1 2.2k there is also x1 brown looking type resistor but it only has 1 black band dead centre of it ('0' Ohm jumper) ive now been advised but there are 23 resistors in this kit plus the odd brown one but only 21 resistors fitted too the pcb when assembled thanks guys for any help you can offer me in building this kit.
« Last Edit: June 18, 2016, 05:45:02 pm by vinceroger »
Offline stj
« Reply #2096 on: June 17, 2016, 08:02:05 pm »
EZM328A files for johnka
The following users thanked this post: johnka
Offline bitseeker
« Reply #2097 on: June 18, 2016, 12:19:14 am »
I'm not quite sure I follow. You listed 23 resistors and I see 23 spots on the PCB for them (R1 - R24 minus R11, which isn't there).
Offline onlooker
« Reply #2098 on: June 18, 2016, 01:29:55 am »
The PCB showed 2 R1s. One of the 2 should be R11. It may be misprinted or damaged.
Offline bitseeker
« Reply #2099 on: June 18, 2016, 02:52:49 am »
Good eye! I see it now. The R1 next to R10 is probably R11.
So, there are spots for all 23 resistors and the zero-ohm jumper.
