Author Topic: $20 LCR ESR Transistor checker project  (Read 3847609 times)
carrascoso and 45 Guests are viewing this topic.
Offline casinada
« Reply #1600 on: December 16, 2015, 05:50:04 am »
Timesbeing,
Google Chrome will automatically translate any page for you. It is not 100% accurate but it will give you a very good idea of what is going on.
The nice thing about the Component tester mentioned above with the AVR processor in the DIP package is that you can use a programmer such as the TL866 to reprogram it. :)
Offline avrank
  • Country: id
« Reply #1601 on: December 16, 2015, 06:38:40 am »
Please help me,
How to make measurements 10uh coil, can be displayed 30uH and not 0.03mH. Thanks.
Well, here goes:
1.) Do the full selftest with a 15 nF capacitor also at hand.
2.) Insert coil at 1 and 3.
3.) Insert 15 nF capacitor in parallel also at 1 and 3.
4.) Press the button.
5.) See what you get. See pic. enclosed
Yours - Messtechniker
Thank you Mr. Messetechniker
Offline timelessbeing
« Reply #1602 on: December 16, 2015, 07:29:17 am »
@casinada
Yes I tried translating. It's difficult to read. I would have to browse through all the topics. It's very easy to miss something, and there may be other German sites that I'm not even aware of. I want to be sure, so I asked here. Plus, everybody else can benefit from the answer too. That's what forums are for. :)
I don't do THAT much programming. $50 seems like a lot to spend to flash a $15 gizmo. I think there some available on eBay for a few bucks.
Offline tom666
  • Country: sk
    • Slovak discussion forum - AVR Component Tester (RLC/ESR & Semiconductors Tester)
« Reply #1603 on: December 16, 2015, 09:37:39 am »
@timelessbeing
You can simply use to programming the MCU the following hardware:
- USBasp programmer (price around US $1.87)
- AVR Development Board (price around US $1.55) - or other AVR ISP adapter
Alternatively, you can use USBasp with a breadboard.
For inspiration:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg810893/#msg810893
« Reply #1604 on: December 16, 2015, 10:02:19 am »
Dík, Tome.
I just won an eBay auction of the USBasp programmer for $1.25 US.
Offline bitseeker
« Reply #1605 on: December 16, 2015, 07:29:01 pm »
Thanks. How do you flash yours, bitseeker?
I haven't reprogrammed mine yet. Instead of reflashing the original, I'm going to buy some new 328 for the newer firmware. That way I also have spares just in case I blow one up by forgetting to discharge a cap (yet another reason I chose this model, with the socketed microcontroller).
As far as programmers, there are many options, as others have posted, above. I have an Arduino Uno, which can also be used as an ISP.
e.g.,
http://www.instructables.com/id/Turn-Your-Arduino-Into-an-ISP/?ALLSTEPS
If you have to buy a programmer, try the USBasp.
Offline eas
    • Tech Obsessed
« Reply #1606 on: December 17, 2015, 12:15:59 am »
I searched online for a suitable device to buy, and this one seemed like the best option:
eBay item: 221952423890  seller: kiss_buyer  cost: 15.97 USD
Pros:
  • socketed ATMega328
  • 128x64 backlit graphical display with support standoffs
  • Rotary encoder
  • Square wave gen, PWM, frequency counter
  • 8Mhz external crystal oscillator
  • Very reasonable price
  • Top-rated eBay seller
Cons:
  • assembly required
  • I don't see pads for programming the MCU in-place, which means I would need a socketed programmer like this one, right?
Did anybody else find any similar gems?
A number of us have built that one recently and been quite happy with it.
The main complaint has been that the optional case doesn't accommodate the ZIF socket provided with the PCB kit, and the socket provided with the case is sub par. I think the simplest solution I've seen posted is to stack one or two IC sockets to elevate the ZIF socket and then cut the case to accommodate it. I fitted the case with three 2mm banana sockets that I could use with test leads, or with a ZIF socket mounted on protoboard with banana plugs sticking out the bottom.
Also, some, including me, have seen corrupted characters, which is solved by flashing new firmware.
I think the lack of programming pins/pads is a bigger annoyance than it is with some of the other testers with a socketed MCU since the display is screwed down over it. I plan to bodge on some programming leads and expose a connection through the battery compartment so I can reprogram mine without having to disassemble the case and display
« Last Edit: December 17, 2015, 12:21:47 am by eas »
Offline hapless
« Reply #1607 on: December 17, 2015, 01:40:35 am »
I was thinking the same thing, just add some leads to put a programming socket into the battery compartment, but what stops me from doing it is the fact that it will add some stray capacitance. With wires moving around inside the case, it will be variable and somewhat difficult to cancel out.
Cons:
  • assembly required
When did this become one of the cons for an electronics hobbyist?  :o
« Reply #1608 on: December 17, 2015, 10:29:11 am »
I won't bother with a case. It doesn't feel right. I do like the idea of having 2 or 4 mm sockets though. That would make it more versatile, and easy to use with existing leads.
I hadn't thought about the screen blocking the MCU. Oh well, hopefully I won't be flashing too often. I'll just see how it goes.
Don't get me wrong. I love building up electronics. But in this case, I would rather spend my time either using the tester to identify parts to use for my projects, or making improvements on the tester. I like the idea of a compact pre-assembled board with a low profile surface mount parts. It's going to be a hassle obtaining through hole 0.1% resistors for the probe circuit. Maybe I'll just bodge in SMCs.
« Reply #1609 on: December 17, 2015, 11:05:46 am »
One of participants of the forum mikrocontroller.net suggested to add in makefile a line "WITH_SamplingADC = 1" that increases permission in this range to 0,01pf. Measurement needs to be done on TP1-TP3 pins.
The additional measurement for low capacitance was submitted by PA3FWM.
Is this documented somewhere? Will it be enabled by default in future version?
There will be also one for low inductance (based on a resonant circuit with a parallel known C). The problem is that the firmware with both new features ... will exceed the flash size limit of the ATmega328... we're heading to the 644/1284 to allow new features and options.
Any updates on this? I assume that upgrading won't be achieved by simply swapping the MCUs, and would require redesigning the hardware?
Offline madires
  • A qualified hobbyist ;)
« Reply #1610 on: December 17, 2015, 12:07:12 pm »
Please see Karl-Heinz' excellent documentation ( https://github.com/svn2github/transistortester/blob/master/Doku/trunk/pdftex/english/ttester.pdf ). The feature is an option and can be enabled in the Makefile of the k-firmware. Currently I have no plans for adding it to the m-firmware, because I think it's a feature for a precision bench multimeter and would require a 4 wire measurement for proper results.
The 644/1284 has a few pins more than the 328 ;) There's a circuit in the documentation, but I don't know if that is going to be the new standard one. I think we need some discussion of the use of the additional I/O pins. It would be good to have a fixed internal SPI bus with a few /CS lines for display, touchscreen and some new option, maybe also a I2C.
Offline tom666
  • Country: sk
« Reply #1611 on: December 17, 2015, 12:20:38 pm »
This DIY KIT with 128x64 G-LCD already contains 0.1% precision resistors (680 and 470k).
Offline eas
    • Tech Obsessed
« Reply #1612 on: December 17, 2015, 11:35:08 pm »
I had a previous model without a case (or rotary encoder). I got tired of being extra careful with it.
The screen is relatively easy to remove. I don't think it would be an excessive hassle for the occasional firmware update. It probably would be if you were doing development, or in the habit of installing nightly builds.
Ah yes, I meant to mention that. It comes with precision resistors, and, at least in my case, they were all well within spec.
Offline bitseeker
« Reply #1613 on: December 18, 2015, 12:03:11 am »
In the kit I got, all but one was within spec (680.80?). But, the ratios still work out fine.
Offline bitseeker
« Reply #1614 on: December 18, 2015, 12:14:59 am »
Anyway, if you do decide to get this model, it's a good price for it. The best deal I found was a short-lived sale on Banggood at $14.93 back in September.
« Reply #1615 on: December 18, 2015, 09:16:05 am »
Thanks for answering all my questions guys. :-+
The hardware is on its way. I'll report back with any interesting updates.
Offline Intel
« Reply #1616 on: December 18, 2015, 03:47:13 pm »
Hello,
I bought the LCR-T4 version from ebay and now I'm trying to modify it to run on 18650 battery but I need to adjust battery voltage settings. I uploaded the .hex file from "mega328_T3_T4_st7565" and it seems to be working. Then I tried adjusting BAT_POOR setting and compiling, but it does not fit in size even with default makefile:
8 MHz operation configured.
AVR Memory Usage
Device: atmega328p
Program:   37102 bytes (113.2% Full)
(.text + .data + .bootloader)
Data:        464 bytes (22.7% Full)
(.data + .bss + .noinit)
EEPROM:       46 bytes (4.5% Full)
(.eeprom)
I'm using latest WinAVR (from year 2010 lol). Tried atmel gnu toolchain but it gave me errors when compiling. Any ideas why it gets so large?
Thanks
Offline madires
« Reply #1617 on: December 18, 2015, 03:59:45 pm »
Please try a recent version of avr-gcc (better optimization)!
Offline madires
« Reply #1618 on: December 18, 2015, 04:15:29 pm »
Quick update on the m-firmware:
- Bug: The test button won't exit the IR detector when the IR receiver module is removed too early (endless loop).
  This is already fixed for the next version.
- IR detector: Trendy edition will support standard RC-6.
- Trendy edition will support two profiles for self-adjustment values (load & save), e.g. for two sets of probes.
Offline tom666
  • Country: sk
« Reply #1619 on: December 18, 2015, 06:05:06 pm »
If you do upgrade the AVR-GCC (I recommend to version 4.8.1) then try this fix of the compilation error (applies to Win 8, 8.1 & 10):
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg818096/#msg818096
Note:
Check the version of the compiler with command "avr-gcc --version".
Offline eas
    • Tech Obsessed
« Reply #1620 on: December 18, 2015, 07:34:00 pm »
Thanks for implementing this!  I'll have to give it a try soon.
Offline bitseeker
« Reply #1621 on: December 18, 2015, 07:42:48 pm »
That's excellent, madires. I haven't looked if there's room hardware- or software-wise, but it would be neat to have a toggle/slide switch connected to a pin on the 328 that would tell it which profile to use.  :-/O
Offline madires
« Reply #1622 on: December 18, 2015, 10:02:38 pm »
I think, v1.21m is going to be a "happy new year" release  ;)
« Reply #1623 on: December 18, 2015, 11:11:37 pm »
A number of us have built that one recently and been quite happy with it...
Is there pre-compiled firmware for my device?
Is it "mega328_st7565_kit" in the trunk directory?
It would be nice to use until I get familiar with compiling and all the make options.
Offline madires
« Reply #1624 on: December 19, 2015, 12:00:57 pm »
Yup!
