Here's a high-level summary of some of the variations:
6. With or without ISP connector.
In the case of non-socketed processors you will need the ISP connector for flashing.
Since I wanted to help development of this thing, I went for the GM 328. It has a socketed processor.
So it is easy to flash externally and replace if damaged. Can easily happen when connecting
large capacitors which are still charged. A protection circuit would prohibit measurements
on other components.
Yours Messtechniker
