I check everything lot of times,5volts are there (pins 7,20 ) when I press the button,stops when I release...Some times is working Ok some times not. Board is checked for everything wrong under the microscope,all solderings,joints,etc are perfect,all parts are OK,double and triple checked...
when it refuses to power on shows this pic:
