Hi!
i've been busy for day's trying to reanimate my BSide ESRPro02
It died a while ago when i accidentally zapped it with a capacitor hahaha
I've replaced the atmega328p
i'm not a programmer, so compiling etc. is a real headache for me...
After long searching & trying I managed it.
Luckily i found a compiled firmware and burned it with a usbasp cable with avrdudess
This was the only decent working firmware... At least i thought it was.
The are some issues, i shall add the pictures..
I compared the measurements with other tools and i got some weirds results
A cap from 2000uF 0.0 esr measures as 5967uF 0.0 esr
A cap from 4484uF 0.01 esr measures as 13.52mF 0.0 esr
Somehow the capacity triples at higher values
A cap from 35uF 1.48 esr measures as 36.98uF 0.0 esr
So that's kinda odd because it's not linear, and the esr isn't working also...
An resistor from 993r measures as 992.1r
An resistor from 10.01k measures as 12.2k
An resistor from 990k measures as 993.7k
Kinda weird though that 10k resistor is way off, while an 1k & 1m resistor are quite spot on
and sometimes the measurement switches between resistor & Coil?
Maybe i did something wrong? i really have no clue... hopefully someone can help me out
