Author Topic: $20 LCR ESR Transistor checker project  (Read 3937521 times)
jellytot, Fuzzy Star, carrascoso, Obelix2007 and 13 Guests are viewing this topic.
Offline oitar
« Reply #9475 on: May 31, 2024, 12:07:54 pm »
So, 324 out, 644 in, plenty memory available for more features :-+ The issues with the bandgap reference(reported last year) are all gone- so the 324 was defective to start with. Looks like the Auto-adjustment is quite sensitive, and gives error if the probes are not plugged really tight.
Next- rotary encoder, low-tolerance resistors and external voltage reference.
Quick question: I've noticed the zener measurement goes progressively(and proportionally) off- from spot-on at 0.5 V to about 2 V over the actual voltage at 25 V. The Auto-adjustment doesn't fix it(even when completed successfully). Is there a way I can tweak it manually?
Offline madires
  • A qualified hobbyist ;)
« Reply #9476 on: May 31, 2024, 02:13:58 pm »
The TC-1/T7 uses just a resistor (10k) to limit the current for the Zener check, i.e. the test current will decrease as the Zener's V_Z increases, and vice versa. The Zener voltage will vary with the changing test current, especially with a too low current. A better solution would be to use a constant current source (as in the ATmega644 circuit in Karl-Heinz' dccumentaion).
Offline Feliciano
  • Country: ve
« Reply #9477 on: May 31, 2024, 08:51:19 pm »
FYI: To be added to the list of non-supported clones, I've just spotted an STC '51-based DIP40 unit, with a text-based (1602) display.
« Last Edit: May 31, 2024, 10:35:14 pm by Feliciano »
Offline hapless
« Reply #9478 on: May 31, 2024, 11:02:08 pm »
Doesn't look like a clone. Looks like a dedicated L/C meter. Does the display claim that it's anything else?
Online indman
  • Country: by
« Reply #9479 on: June 01, 2024, 06:46:49 am »
This is an DIY F/L/C meter and is not relevant to this project.
https://www.aliexpress.com/item/3256806396807109.html?_randl_currency=USD&_randl_shipto=US&src=google
« Last Edit: June 01, 2024, 06:50:19 am by indman »
Offline Feliciano
  • Country: ve
« Reply #9480 on: June 01, 2024, 12:34:22 pm »
Reading at the screen of the sample picture, yes, you're right, but the banggood title says "Transistor Tester Resistance Capacitance Meter Tester Digital Frequency Meter Multi-function Measurement Electronic DIY Kit ". So, another misleading seller.
Offline wesk18
« Reply #9481 on: June 02, 2024, 10:17:23 pm »
running firmware ComponentTester-1.41m, is it possible to add the autobots logo or any other logo to the fish8840-tft?
Offline madires
« Reply #9482 on: June 03, 2024, 08:01:56 am »
No, but you could modify the firmware to add that feature. The most simple way would be to utilize LCD_Symbol() and split the logo into tiles (same size as the symbols).
Offline LeWidget
« Reply #9483 on: June 04, 2024, 03:14:09 pm »
Hey all,
Picked up a tester, LCD-T7, it was $14.50aud so I thought why not, though it's a bit different than what I've seen. The chip seems to be unmarked so I assuming it's non-authentic? The battery is also built in rechargeable & doesn't use a 9v like others.
Can I do anything with it? Unfortunately it doesn't have the pads for testing Surface-mount components, unless there's a way to test in the slots.
Also, can anyone explain the 123|1232? How is this used to test?
Online Kim Christensen
« Reply #9484 on: June 04, 2024, 03:21:43 pm »
1,2, & 3 are the test points. All the ones are connected/grouped together. As are the twos. As are the threes. It just allows you to insert parts with different lead spacing easier.
Be aware that the K & A will output around 30V and are for testing zener diodes only.
Don't put a capacitor into K & A and then immediately stick it into 1,2,3 because that'll destroy the tester. Always make sure capacitors are fully discharged before testing them.
« Last Edit: June 04, 2024, 03:24:58 pm by Kim Christensen »
The following users thanked this post: LeWidget
Offline LeWidget
« Reply #9485 on: June 04, 2024, 03:36:35 pm »
Thanks Kim, much appreciated :)
So, when testing, I don't do 1+1, I have to do 1+2, 1+3, 2+3, 1+2+3?
What does the K & A mean?
Ouch, thanks for the heads up lol. I think I did that with an LED earlier  :palm:, lucky it wasn't the capacitor.
Any idea why they would include 1x capacitor, 1x LED, 3x (what appears to be) wire terminals?(see attached pic)
« Reply #9486 on: June 04, 2024, 04:31:16 pm »
Yes.
Cathode and Anode.
The 3-wire terminals (Actually crimp pins) are for calibration. If you insert them, as is, into 1,2&3 and press "start" then the unit will go into self calibration mode.
Not sure if the Chinese firmware also will ask for a capacitor during self calibration. Usually you use a better quality film capacitor than the one they gave you.
The LED is just a bonus part for checking the tester. It'll flicker as it gets tested.
« Last Edit: June 04, 2024, 04:32:50 pm by Kim Christensen »
Offline LeWidget
« Reply #9487 on: June 04, 2024, 05:09:35 pm »
Thanks again Kim :)
I ran a test, seemed to come back ok (see pic). Didn't ask for a cap though.
Offline oitar
« Reply #9488 on: June 05, 2024, 10:37:38 am »
Brag time ;)
1. Original Atmega324(slightly defective) replaced with Atmega644.
2. The power management ic replaced with the 2 transistor hack(see attached, yeah looks like a dog's breakfast, but it works nicely; will put a bit of hot glue over).
3. Button replaced with rotary encoder- helps prevent arthritis from multiple button presses :-+
4. Don't think I'll even replace the probe resistors- I'm happy with the precision already.
Changing the zener testing to separate terminals- away from the zif socket should be done as a matter of necessity, sooner or later one will forget either a charged cap, or  the probes in the wrong zif pins, and toast the cpu.
Cheers to all, thanks @madires for still keeping the upgrades going, and answering even the dumbest questions!
Offline BennehBoy
« Reply #9489 on: June 10, 2024, 02:24:49 pm »
I've just come to use my T7 after quite a period of none use and found that the screen repeatedly cycles between full white and off whilst trying to charge the unit.
I'm assuming that it's been killed at some point - maybe even the last time I used it...
I've not read all 380 pages (eeek!), and a quick google did not turn up a similar symptom, but any ideas?
I'm hoping it's just a case of reflashing something/doing the transistor mod on the STC15L104W.
Thanks
Offline Calambres
    • Piso-Tones
« Reply #9490 on: June 10, 2024, 03:49:19 pm »
I also have an AY-AT with genuine DIL ATMEGA328 chip that suddenly and randomly started to write some crap characters on the screen.
Quite annoying if you ask  ::)
Offline madires
« Reply #9491 on: June 10, 2024, 04:19:44 pm »
Please check the voltage of the LiPo battery. It's possibly very low (deeply discharged). If charging doesn't help try a new battery.
Offline BennehBoy
« Reply #9492 on: June 10, 2024, 04:28:23 pm »
It was very low - 0.1v when I checked it just before the time of my last post.  It's been sat trying to charge since then, will check it shortly.
UPDATE - no change to the voltage, I guess it's toast?
« Last Edit: June 10, 2024, 04:30:25 pm by BennehBoy »
Offline Yuriy_K
  • Country: ru
« Reply #9493 on: June 10, 2024, 04:53:40 pm »
For those who see similar readings on silicon transistors on the k-firmware, which is incorrect (upper left corner). This is not a program error, but an incorrect measurement scheme. If we add inductance and capacitance to the scheme, highlighted in red SMD, we get correct readings for silicon transistors. For germanium transistors, measurements are shown - lower right corner.
Offline madires
« Reply #9494 on: June 10, 2024, 07:37:58 pm »
Yep, the LiPo battery needs to be replaced. I'd recommend also to add a small switch to the battery (to prevent draining it by the high quiescent current).
Offline madires
« Reply #9495 on: June 10, 2024, 07:41:58 pm »
Also recommended by the ATmega's datasheet, i.e. a small inductor plus cap for the ADC's power supply.
Online indman
  • Country: by
« Reply #9496 on: June 10, 2024, 08:05:16 pm »
Here is a reply from Karl-Heinz Kübbeler on the advisability of using a inductance(throttle-coil) in the AVCC power supply circuit:
"There is no need to use a throttle (coil) for the AVCC supply.
During the ADC period no digital activity disturb the VCC power supply.
Any inductance in the AVCC supply also have a resistance.
The influence of the resistance of the coil probably interfere the
measurement result more then a remaining noise at the VCC power.
The enhancement of ADC resolution requires a noisy or unstable signal.
The mean value of several input values is always the input value itself,
if there is no change of the value. Only if the input signal changes a
little bit, the mean value can interpolate the steps of the ADC by
a statistically effect. For example the mean value of
10, 11, 11, 12, 11, 10, 11, 10, 11, 11 is 10.8 ! "
« Last Edit: June 10, 2024, 08:13:09 pm by indman »
Offline madires
« Reply #9497 on: June 10, 2024, 08:54:02 pm »
There's no simple answer. It depends on how well the power supply circuitry is designed. Some Vcc ripple helps (is necessary) with the ADC (averaging multiple readings). But a sudden larger load change will cause a short drop/rise of Vcc. With a marginal power supply and no inductor for AVCC the ADC's 5V reference voltage would change too. The LC filter reduces that change of AVCC. For a proper power supply the LC filter isn't really needed (might even be counterproductive). But for a poor one it can be a good idea. And the values of the LC filter should be choosen to suppress ripple to some extend while keeping enough noise for the ADC. This is also one of the reasons why some clones deliver results which are a bit off.
Online indman
  • Country: by
« Reply #9498 on: June 10, 2024, 09:01:00 pm »
It is a good idea for poor and rich people to make a quality power supply for this device that is not afraid that a sudden change in load will cause Vcc to drop/rise, thus eliminating unnecessary parts in the form of external REFs, coils, i.e. crutches for the lame.
« Last Edit: June 10, 2024, 09:10:18 pm by indman »
Offline BennehBoy
« Reply #9499 on: June 10, 2024, 09:59:41 pm »
I've ordered a larger capacity lipo (that will fit the case) and will certainly be adding a switch, thanks.
