After surviving the April's Fool Day here's the real deal. Get your programmer ready and enjoy!
v1.52m
- Added quick-check tool for diodes and LEDs (SW_DIODE_LED).
- Support for BH1750VFI ambient light sensor (HW_BH1750).
- Fixed protocol issue for addressing chips in read mode in function I2C_WriteByte() for bit-bang I2C.
- Fixed scaling error in the voltage divider calculation in T2 of the Self Test function.
- Option for packed output format of font display for test purposes (FONT_PACKED).
- Added new font font_8x16_alt_hf.h (FONT_8x16_ALT_HF, thanks to Feliciano@EEVblog).
- Corrected bitmap for O umlaut in font_8x16_iso8859-2_hf.h (thanks to Feliciano@EEVblog).
- Fixed data byte issue in I2C_ReadByte() for hardware TWI (reported by fail@mikrocontroller.net).
- Corrected the colors for 0.1 and 0.01 multipliers in Display_ColorCode() (reported by chaoslegion@VRTP).
- Option to switch temporarily to auto-hold mode after a component is found (in continuous mode, UI_AUTOHOLD_FOUND, suggested by Maniaxx@EEVBlog).
- Added option to optimize the interrupt vector table to reduce firmware size (Makefile: OPTIMIZE_VECTORS, thanks to Viktor Klimkovich).
- Improved UJT detection to exclude potentiometers with a specifc resistance (3-15 k) and the wiper turned to one end (reported by wandows@EEVblog).
- Fixed issue with return value in DataStorage() (thanks to Viktor Klimkovich).
- Fixed detection issue of small capacitances which was caused by the newly added negative zero offset in LargeCap() (reported by Yuriy_K@EEVblog and Obelix2007@EEVblog).
Please download at:
https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware-
https://github.com/kubi48/TransistorTester-source/tree/master/Markus (soon)
