Author Topic: $20 LCR ESR Transistor checker project  (Read 3962222 times)
wandows and 5 Guests are viewing this topic.
Online indman
  • Country: by
« Reply #9125 on: February 13, 2024, 04:18:32 pm »
NF6X, I, for example, it does not bother me in any way, and I will not and do not want to bother with hypotheses as to how and why details absolutely unnecessary for the project appeared. If you are so concerned about it, ask a Chinese engineer, such as FNIRSI, directly!
Offline Feliciano
  • Country: ve
« Reply #9126 on: February 13, 2024, 04:20:52 pm »
Agree. Please lets focus on the matter in question: how to make this work with OSHW firmware.
Online indman
  • Country: by
« Reply #9127 on: February 13, 2024, 04:29:57 pm »
Feliciano,you have checked the display connection and identified the controller pins. Are the rest of the peripherals connected in the standard way or are there also differences from the original circuit? There are a lot of unclear points on the schematic you showed earlier, the pins of the ATMega324 are not labeled. It would be nice if you could draw a more detailed circuit diagram.
Offline Feliciano
  • Country: ve
« Reply #9128 on: February 13, 2024, 04:31:54 pm »
Indeed:
I'm checking this soldered display, and uses a different pin mapping (from right to left bottom-view):
1=GND, 2=Vcc, 3=PB4 (44), 4=PB3 (43), 5=PB5 (1), 6=PB7 (3)
And not all the pins are labeled because I'm writing over an m328p schematic [WIP].
« Last Edit: February 13, 2024, 04:34:20 pm by Feliciano »
Online indman
  • Country: by
« Reply #9129 on: February 13, 2024, 04:34:54 pm »
That's understandable, that's not what I'm asking. To which ports are connected 6 measuring resistors, ION, calibration capacitor, IR detector?
This is all to be considered when customizing new firmware.
Offline 2hry
  • Country: at
« Reply #9130 on: February 13, 2024, 05:42:19 pm »
@Feliciano
Your tester looks like my JOYIT T7.
I have removed the Stc chip, and flashed m-firmware.
It is not working anymore, because the srv05 got damged, but i made some notes of the pinout.
LCD_RES          PB4
LCD_DC           PB3
LCD_SCL          PB7
LCD_SDA          PB5
LCD_OFFSET_X     2
LCD_OFFSET_Y     1
LCD_FLIP_X
TP1              PA0
TP2              PA1
TP3              PA2
TP_ZENER         PA4
TP_REF           PA3
TP_BAT           PA5
TP_CAP           PA7
R_RL_1           PC0
R_RH_1           PC1
R_RL_2           PC2
R_RH_2           PC3
R_RL_3           PC4
R_RH_3           PC5
POWER_CTRL       PD7
TEST_BUTTON      PB2
IR_DATA          PD3
ADJUST_RH        PC6
The following users thanked this post: madires, Feliciano
Online indman
  • Country: by
« Reply #9131 on: February 13, 2024, 05:53:14 pm »
The tester can work without SRV05, unless, of course, the microcontroller is also damaged.
You could provide the firmware so Feliciano can test it on his clone.
The following users thanked this post: Feliciano
Offline 2hry
  • Country: at
« Reply #9132 on: February 13, 2024, 06:43:57 pm »
I think the microcontroller is damaged.
It didnt start anymore and the srv05 got hot. So i removed it and the tvs, but it always measures a battery on pin2.
and compiled it in english again if anyone is interested.
Offline Feliciano
  • Country: ve
« Reply #9133 on: February 13, 2024, 07:37:41 pm »
Indeed 2hry firmware worked, and as madires suggested, without further hardware modifications. Thank you very much dears.
Now my unit is running 1.51m (STC no longer needed, removed). And with the hints on the pin assigments, I will work on the original configs for customization.
FWIW (maybe for the clones files), attached a comparison of some clones' PCBs (JOYIT, FNIRSI on the right).
PS: It also looks to me that 2hry's MCU is damaged.
« Last Edit: February 13, 2024, 08:40:43 pm by Feliciano »
Offline rddube
« Reply #9134 on: February 13, 2024, 07:55:06 pm »
Hello everyone,
Programmed my TT with version 1.51m and when I try to put it into L Monitor (inductance) it just stands on the screen in the photo and won't read anything and won't respond to the button press either.
What did I do wrong to not have it give my inductance readings?
Many thanks,
Raymond
Offline carl1961
« Reply #9135 on: February 14, 2024, 12:30:59 am »
what version is this?
Offline rddube
« Reply #9136 on: February 14, 2024, 03:24:32 am »
You mean the Ttester, it is version ST7565R .
The following users thanked this post: carl1961
Online indman
  • Country: by
« Reply #9137 on: February 14, 2024, 05:32:19 am »
Enable the RLC Monitor mode in the firmware. Will the tester in this mode react to the connection of resistance, capacitance, inductance?
Feliciano, To which ports of the ATmega324 were pins 7 and 8 of the STC connected? I've almost updated the circuit diagram for FNIRSI's LCR-TC1.
« Last Edit: February 14, 2024, 05:35:37 am by indman »
Offline madires
  • A qualified hobbyist ;)
« Reply #9138 on: February 14, 2024, 10:52:39 am »
LCD_RES          PB4
LCD_DC           PB3
LCD_SCL          PB7
LCD_SDA          PB5
Have you configured bit-bang SPI or hardware SPI? With that pin assignment hardware SPI should be possible.
Offline Feliciano
  • Country: ve
« Reply #9139 on: February 14, 2024, 11:42:52 am »
@madires: I don't know about the firmware binaries 2hry shared, but with 1.46m I enabled bitbang for the old TC1 (now I recall you said hardware SPI was not possible) and I did the same for the new one; and with 1.51m I got undefined function errors when trying to enable the default hardware SPI for the FNIRSI, so I choosed bitbang as well.
Sidenote: I'm using 1.46m now because the same set of features represent 99.7% usage on that, and 100.6% (32980B) on the other. I was planning to try intermediate versions, or perhaps you can suggest what to remove for this particular unit in order to save some Bytes.
@indman: the STC was connected to traditional PD1 and PD2. I attach the updated draft diagram for comparison.
Thank you both.
« Last Edit: February 14, 2024, 12:14:03 pm by Feliciano »
Online indman
  • Country: by
« Reply #9140 on: February 14, 2024, 12:14:03 pm »
On such a small display 1.8 we should not notice any difference in speed, or are there any other important factors that indicate the usefulness of hardware SPI?
Offline Feliciano
  • Country: ve
« Reply #9141 on: February 14, 2024, 12:36:06 pm »
If code-wise hardware SPI would save some Bytes (vs software SPI), that alone would it be useful/worthy.
« Last Edit: February 14, 2024, 12:38:59 pm by Feliciano »
Offline rddube
« Reply #9142 on: February 14, 2024, 01:05:16 pm »
Hello Indman, when I enable RLC Monitor, tester reacts to resistance, capacitance perfectly, when I try to test an inductor, it gives me a resistance reading... Thank you for your help!
Online indman
  • Country: by
« Reply #9143 on: February 14, 2024, 01:10:56 pm »
This means that the tester cannot determine the inductance because it is too small or its resistance is greater than 2 kOhm.
Offline madires
« Reply #9144 on: February 14, 2024, 01:25:00 pm »
You could disable checks for rare components (SW_UJT, SW_SCHOTTKY_BJT).
Offline madires
« Reply #9145 on: February 14, 2024, 01:34:34 pm »
A slightly smaller firmware size, as Feliciano already pointed out. And the most visible impact would be a faster screen clearing.
Offline rddube
« Reply #9146 on: February 14, 2024, 02:28:32 pm »
But whatever size I put it always gives me a resistance reading. Can it not read a 1uh 1R0 inductor ? These are inductors around a CPU on a motherboard. What is the range that it can read? Many thanks.
Online indman
  • Country: by
« Reply #9147 on: February 14, 2024, 02:33:35 pm »
rddube,The lower range of inductance measurements on m-firmware starts at about 10 microHenry. If you want to measure inductance values ​​lower than 10 microHenry, you can build an additional LC meter attachment or use the resonant method in k-firmware.
Offline Feliciano
  • Country: ve
« Reply #9148 on: February 14, 2024, 02:46:35 pm »
I'm for it. So let's do the 1.51m exercise again (32980B vs X) and please help me troubleshoot my configuration. I enabled
SPI_HARDWARE both on config and config_644, and disabled SPI_BITBANG on the first. I thought that would be enough for the Make, but I get the following errors:
SPI.c: In function 'SPI_Clock':
SPI.c:388:10: error: 'SPCR' undeclared (first use in this function)
   Bits = SPCR;                            /* get control register */
SPI.c:388:10: note: each undeclared identifier is reported only once for each function it appears in
SPI.c:389:19: error: 'SPR1' undeclared (first use in this function)
   Bits &= ~((1 << SPR1) | (1 << SPR0));   /* clear clock rate bits */
SPI.c:389:33: error: 'SPR0' undeclared (first use in this function)
SPI.c:406:18: error: 'SPI2X' undeclared (first use in this function)
     Bits = (1 << SPI2X);           /* set bit to double SPI speed */
SPI.c:409:3: error: 'SPSR' undeclared (first use in this function)
   SPSR = Bits;                     /* update register */
SPI.c: In function 'SPI_Setup':
SPI.c:444:3: error: 'SPCR' undeclared (first use in this function)
   SPCR = (1 << SPE) | (1 << MSTR);
SPI.c:444:16: error: 'SPE' undeclared (first use in this function)
SPI.c:444:29: error: 'MSTR' undeclared (first use in this function)
SPI.c:450:10: error: 'SPSR' undeclared (first use in this function)
   Bits = SPSR;           /* read flag */
SPI.c:451:10: error: 'SPDR' undeclared (first use in this function)
   Bits = SPDR;           /* clear flag by reading data */
SPI.c: In function 'SPI_Write_Byte':
SPI.c:469:3: error: 'SPDR' undeclared (first use in this function)
   SPDR = Byte;                     /* start transmission */
SPI.c:470:12: error: 'SPSR' undeclared (first use in this function)
   while (!(SPSR & (1 << SPIF)));   /* wait for flag */
SPI.c:470:25: error: 'SPIF' undeclared (first use in this function)
make.exe: *** [SPI.o] Error 1
> Process Exit Code: 2
Offline madires
« Reply #9149 on: February 14, 2024, 03:27:35 pm »
If you enable SPI_HARDWARE in config_644.h you don't need to do that also in config.h (it will trigger a compiler warning). The error messages about undeclared register names could be caused by a missing header file. That should be avr/io.h (#include <avr/io.h> which is included in common.h). Try an additional #include <avr/io.h> in SPI.c.
