jdev99
A competent and simple solution, as indicated in the screenshot. Selection of the most optimal current and its stabilization for safe testing of high-power and middle(low)power zener diodes.
For more precise adjustment of the measured voltage on the zener diode, in k-firmware the Makefile contains lines for the input resistor divider
# Voltage divider for the external zener voltage measurement 180k / 20k = 10/1
CFLAGS += -DEXT_NUMERATOR=10
CFLAGS += -DEXT_DENOMINATOR=1
Instead of a decimal value, you can use the following numbers for smoother voltage adjustment
CFLAGS += -DEXT_NUMERATOR=100
CFLAGS += -DEXT_DENOMINATOR=10
In your case, to reduce the voltage, you can, for example, try the following values
CFLAGS += -DEXT_NUMERATOR=120
For m-firmware, similar divider settings are in the config.h file
#define ZENER_DIVIDER_CUSTOM
#define ZENER_R1 180000
#define ZENER_R2 20000
