Is there an easy way to disable continuous mode with Markus’ firmware? I find it’s a bit wasteful for me, since I’m not testing a string of components at a time. Also, I’ve got to say that this firmware feels a lot slower than the version in the trunk directory. Maybe it’s something in my settings?
Edit: I set #define CYCLE_MAX to 1 in config.h, but it still seems to go more than once sometimes (I know if I hit the button after a measurement it’ll go again, but I don’t touch anything and it’ll go again once and awhile it seems; mainly after I’ve just measured a component).
On another note, I got my reference installed. Works great!
That big capacitor that’s folded over next to the reference board is a 10uF I added to help filter the output of the voltage regulator. Turns out they have *no* capacitor directly on the output! (I’ve got it soldered to the pin of a resistor which is the first thing the regulator’s output connects to [first solder connection coming from the regulator’s tab in the second picture].) This should help keep the regulator’s output a lot more stable.
