What do I need to enable to test Zeners on the AY-AT through hole model? When I built my tester, I made sure the 180k and 20k resistors were well under 1% accuracy.
The config has these options it seems
//#define HW_ZENER
//#define ZENER_DIVIDER_CUSTOM
//#define ZENER_R1 180000
//#define ZENER_R2 20000
//#define ZENER_UNSWITCHED
//#define ZENER_SWITCHED
//#define ZENER_BOOST_HIGH /* high active */
//#define ZENER_BOOST_LOW /* low active */
//#define HW_PROBE_ZENER
//#define ZENER_VOLTAGE_MIN 1000 /* min. voltage in mV */
//#define ZENER_VOLTAGE_MAX 30000 /* max. voltage in mV */
Thank you for your reply! Today I have successfully compiled on another PC with Windows 7 64 bit operating system installed. This means that after updating Windows 10 64-bit on the main PC, my compiler does not work correctly.
I am running windows 10, 64 bit and have managed to get it to work.
I followed sort of this guide that madires kindly linked for me
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/2475/
the link for toolchain would not work for me (funnily enough it does now) and I ended up getting version avr8-gnu-toolchain-3.7.0.1796-win32.any.x86_64
I am using WinAVR on windows 10 and when I tried to compile I got an error message, the fix was to go to the installation folder for winavr on the C: drive and search for patch.exe
If you run that it opens a command prompt page. You have to leave it open and go back to the winavr running program and it should compile. Or mine does anyway.
