Get your ISP programmer ready!
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
v1.49m:
- Alternative pinouts for IR receiver module (SW_IR_RX_PINOUT_G_V_D, SW_IR_RX_PINOUT_D_G_V, SW_IR_RX_PINOUT_D_V_G, suggested by boleslaw_43@mikrocontroller.net).
- Fixed capacitor detection issue in ESR tool. Happened after a semiconductor was found before by normal probing (reported by indman@EEVblog).
- Fixed bug in configuration management for touchscreens.
- Added check for frequency counter options to config_support.h.
- Moved code for counter tools from tools_signal.c to new tools_counter.c.
- Added checks for SPI_PIN and SPI_MISO to config_support.h in case bit-bang SPI with read support is enabled. Also extended SPI section in all
config_<MCU>.h for easier handling.
- SW_R_TRIMMER shows now also the ratio of the second resistor (suggested by wandows@EEVblog).
- Display OneWire device symbol in DS18B20, DS18S20 and DHTXX tool (UI_ONEWIRE, suggested by indman@EEVblog).
- Added symbol for OneWire devices to all symbol sets (thanks to indman@EEVblog).
- Support for temperature sensor DS18S20 (SW_DS18S20, DS18S20_HIGHRES, suggested by indman@EEVblog).
- Added checks for Darlington BJTs to CheckProbes() & CheckDepletionModeFET() to prevent false detection as JFET in case EMI issues cause a high leakage current (reported by wandows@EEVblog).
- Fixed bug in check for Germanium PNP BJTs in CheckDepletionModeFET().
- Added configuration switch for sequential COM pin layout to OLED drivers for SH1106 and SSD1306 (LCD_COM_SEQ), and a switch for reversed COM mapping to the SSD1306 driver (LCD_COM_REMAP, suggested by boneDragon@EEVblog).
- Added support for a passive buzzer (BUZZER_ACTIVE or BUZZER_PASSIVE, suggested by boneDragon@EEVblog).
- Texts in Brazilian Portuguese (thanks to wandows@EEVblog).
- Added general purpose switched output, e.g. for an LED flashlight (HW_FLASHLIGHT, suggested by boneDragon@EEVblog).
Please download at
https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware-
https://github.com/kubi48/TransistorTester-source/tree/master/Markus
