....Don't you understand that it is impossible to compare the readings of devices with autonomous power and kicking from a mains power supply?
The sensitivity of the TTester is so high that it reacts to the close presence of hands, like an antenna to influence network interference.
In all my examples, there is no mains power and there are no hand pickups.
So I have both a multimeter and a tester powered by batteries ...
I take into account the influence of the hands, and I understand that they can influence ... but the fact is that when everything is connected and the hands are removed - for some reason, when measuring the cable, this is what happens ...
In all other measurements, the tester and multimeter are almost the same ...
Here ONLY this coaxial cable froze and confused ... it seems to me that even with "noise", there should not be such a large spread ...
But for now, I decided to trust the testimony of the tester (of course, having correctly connected it to the ZIF panel and removed my hands away)
Tell me more please. On page 317 Your options for BGR display - ST7735_BGR_en.zip is this the final option for G328A(BGR)? Those. Can I reflash this k-version over 1.13 color?
I have the m-firmware version 1.44 extreme .... still available
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
