I know that many are unhappy with the tester that contains the APT32F172K8T6 (TC1 in my case).
But if you don't know anything about ATmega and firmware etc., it's not that bad for ~$10 including battery and case.
Despite the small battery, it has a really good endurance.
Once the problem with KAA range is solved (2K2 resistor) there is no reason to throw it away. Imo it's worth the money.
I randomly tested some components (cheap chinese stuff in a big bag). Here are the results.
Imho even the ESR values seem plausible.
Resistors:
680k -> 682k
220k -> 217k
51k -> 53k
3,3k -> 3.28k
100 -> 98.7
Capacitors:
6.8pF -> 6.2pF
470pF -> 520pF
3.3nF -> 3.5nF
220nF -> 240nF
470nF -> 504nF
1μF -> 0.974μF (ESR:4.1Ω)
2.5μF -> 2.41μF (ESR:4.8Ω)
10μF -> 9.78 (ESR:0.98Ω)
22μF -> 24.6μF (ESR:1.5Ω)
33μF -> 32.1μF (ESR 0.8Ω)
47μF -> 49μF (ESR:0.5Ω)
220μF -> 228μF (ESR:0.2Ω)
470μF -> 420μF (ESR:0.13Ω) (Aneng 8080 shows also 420μF).
Diodes:
1N4148 -> Uf=708mV C=2pf Ir=11na
1N4007 -> Uf=703mV C=9pf Ir=8na
FR107 -> Uf=666mV C=10pf Ir=10na
Zener:
3.6V -> 3.6V
5.1V -> 5.1V
12V -> 12.2V
Transistors:
A42: NPN hFE=45 Ube=609mV Ic=5.9mA
BC547B: NPN hFE=344 Ube=774mV Ic=5.9mA
BC547C: NPN hFE=562 Ube=813mV Ic=5.9mA
C1815 : NPN hFE=382 Ube=773mV Ic=5.9mA
C8050: NPN hFE=138 Ube=695mV Ic=5.8mA
C945: NPN hFE=362 Ube=768mV Ic=5.9mA
S9013: NPN hFE=151 Ube=675mV Ic=5.8mA
S9014: NPN hFE=375 Ube=770mV Ic=5.9mA
S9018: NPN hFE=71 Ube=735mV Ic=0.0mA
2N3904: NPN hFE=214 Ube=719mV Ic=5.9mA
2N2222: NPN hFE=289 Ube=717mV Ic=5.9mA
2N3904: NPN hFE=211 Ube=718mV Ic=5.9mA
2N5551: NPN hFE=154 Ube=681mV Ic=5.9mA
A93: PNP hFE=116 Ube=729mV Ic=6.0mA
A733: PNP hFE=385 Ube=890mV Ic=6.0mA
A1015: PNP hFE=358 Ube=884mV Ic=6.0mA
2N5401: PNP hFE=162 Ube=761mV Ic=6.0mA
2N3906: PNP hFE=210 Ube=838mV Ic=5.9mA
S9012: PNP hFE=184 Ube=776mV Ic=6.0mA
S9015: PNP hFE=390 Ube=889mV Ic=6.0mA
S8550: PNP hFE=345 Ube=868mV Ic=5.9mA
It definitely helps to put the components in the right drawer.
