Just bought a tester marked Multi-function Tester - TC1 from ebay. It is never able to test any component but it does boot up ok and the display is ok. It doesn't recognise any components in the 1,2,3 sockets, it just displays "unknown or damaged part" after pressing the start button.
Have you performed the “self-adjustment” procedure?
Do this by shorting test socket pins 1, 2, 3. The metallic strip of 3 crimp pins supplied with these LCR-Txx units can be used for this. Take care to place it so that it shorts pins labeled 1-2-3. Then press the button. It should display “self test.” After 10-30 seconds it should display “isolate probes.” Now pull out the short circuit and it should eventually display “test complete.”
If I put a diode in the (K, A) part of the socket it does recognise it as a zener, so it seems to be stuck in zener mode.
If your tester displays “unknown or damaged part” then it isn’t stuck in zener test mode.
It has a blue PCB with no transformer, uploaded a photo.
The unit in your photo is likely to be a clone using the LGT8F328P MCU.
Unfortunately the software is proprietary and cannot be upgraded. Eventually the open-source Transistor Tester software
might get ported to the LGT8F328P MCU, but I’m not expecting this anytime soon. Note: The LGT8F328P claims to be an improved version of the Atmel ATmega328P. However it isn’t fully compatible at either the hardware (different pinout) or software level. This MCU is made by a Chinese semiconductor company named “LogicGreen.”
I have a similar unit with LGT8F328P MCU. It functions but has issues (inaccurate for some types of transistors). It does measure resistors, capacitors, and inductors reasonably well.
I discovered a way to identify units with LGT8F328P MCU: Press and hold down the button for 30 or more seconds. The display language should switch from English to Chinese. Wait till tester times out and powers off, then press and hold the button for another 30+ seconds to switch back to English.
