Details about MCU chips found in recent production Transistor Testers:Atmel ATmega324 has been used in Transistor Testers for several years, but recently had a big price increase ($5-15 USD) and became harder to get. This MCU has 44 pins (11 pins on each of the 4 sides). ATmega324
is supported by existing -m (Markus) Transistor Tester software. However, ATmega324 software is
not available in -k (Karl-Heinz) version.
Atmel ATmega644 has same 44-pin package as ATmega324 and can be used with same PC board layout. ATmega644 has 64k flash memory compared to 32k for ATmega324. Therefore ATmega644 accommodates larger software with additional testing/measurement capability, higher resolution display fonts, and multiple user-selected languages. ATmega644
is supported by both -k and -m Transistor Tester software versions.
LGT8F328P - First used by Transistor Tester manufacturers in 2021. Price: < $1 USD. 32-pin package (8 pins on each of the 4 sides). This is same package as Atmel ATmega328. It is said to be “similar” to Atmel ATmega328. However its pinout is
different and it has several additional features. For example the LGT8F328P can operate at 32MHz. The LGT8F328P has been ported into the Arduino IDE. Clone versions of Arduino Pro and Nano boards containing LGT8F328P are available. But
no open-source Transistor Tester software for LGT8F328P has been officially released yet. However, one Transistor Tester enthusiast has a GitHub project to adapt the -m software to LGT8F328P:
https://github.com/DurandA/transistor-tester-lgt328pAPT32F172K8T6 - First used by Transistor Tester manufacturers in 2022. Also < $1 USD. 32-pin package (8 pins on each of the 4 sides). Pinout, internal architecture, and instruction set are
totally different than Atmel ATmega328. Only similarity is 32-pin package. Very few development tools are available for compiling and debugging APT32F172K8T6 software. Existing open-source Transistor Tester software does
not support this MCU.
Warning: Unfortunately some Transistor Tester manufacturers are deliberately mis-labeling the APT32F172K8T6 as Atmel ATmega328P. Conclusion:ATmega324 and ATmega644 are the only
44-pin MCU chips found in Transistor Testers.
Therefore a quick look at the PC board will distinguish these MCU chips from the other two.
