This time we have done some work on the display output.
v1.47m:
- Fixed swapped resistor symbols in font_8x12t_iso8859-2_vfp.h and font_8x12t_iso8859-2_hf.h (reported by b0hoon@EEVblog).
- Added option to display quartz crystal symbol for LF/HF modes in extended frequency counter (UI_QUARTZ_CRYSTAL, suggested by indman@EEVblog).
- Added fonts font_8x12t_iso8859-2_hf.h (FONT_8X12T_ISO8859_2_HF) and font_8x16_iso8859-2_hf.h (FONT_8X16_ISO8859_2_HF, thanks to b0hoon@EEVblog).
- Fixed wrong reference of '\' in font_8x8_iso8859-2_h.h, broken diode symbol A-C and 'W' in font_6x8_iso8859-2_hf.h (Thanks to b0hoon@EEVblog).
- Added option to display a Zener diode symbol in any Zener check (UI_ZENER_DIODE, suggested by indman@EEVblog).
- New 32x39 symbol set to match 26 pixel high fonts (SYMBOLS_32X39_HF, thanks to indman@EEVblog).
- Added options to auto-hold ESR and inductance for C and L monitor (SW_MONITOR_HOLD_ESR, SW_MONITOR_HOLD_L, suggested by theHWcave@EEVblog).
- Added character translations for inversed pin numbers to Serial_Char().
- Added option for /RESX line on separate MCU port to ST7735 driver (LCD_RES_PORT, LCD_RES_DDR, based on idea from lhlad@EEVblog).
- Added option to display a question mark symbol in case of a failed test run (UI_QUESTION_MARK, suggested by indman@EEVblog).
- Added symbols for question mark, Zener diode and quartz crystal to all symbol sets (thanks to indman@EEVblog).
- Added additional positioning flags for fancy pinout (PIN_CENTER, PIN_ALT_CENTER, suggested by indman@EEVblog).
- Display small diode symbol in front of Vf for MOSFETs and IGBTs (suggested by indman@EEVblog).
- Added numbers 1-3 and character x with reversed color plus degree character to font_8x16alt_win1251_hf.h. Also updated 1-3 and x with reversed color in font_8x8alt_win1251_vf.h. Same for font_16x26_win1251_hf.h (thanks to indman@EEVblog).
- Added option to disable display of text based pinout of the body diode for MOSTFETs (UI_NO_BODYDIODE_TEXTPINOUT, suggested by indman@EEVblog).
- Added symbol set 32x39 (SYMBOLS_32X39_HF, thanks to indman@EEVblog).
- Added alternative symbols sets 24x24 (SYMBOLS_24X24_ALT1_H, SYMBOLS_24X24_ALT2_H, SYMBOLS_24X24_ALT1_HF, SYMBOLS_24X24_ALT2_HF, SYMBOLS_24X24_ALT1_VFP, SYMBOLS_24X24_ALT2_VFP, SYMBOLS_24X24_ALT1_VP_F and
SYMBOLS_24X24_ALT12_VP_F), 30x32 (SYMBOLS_30X32_ALT1_HF and SYMBOLS_30X32_ALT2_HF) and 32x32 (SYMBOLS_32X32_ALT1_HF and SYMBOLS_32X32_ALT2_HF, thanks to indman@EEVblog).
- Added option to fancy pinout to show right-hand probe numbers above/below the symbol (UI_PINOUT_ALT, suggested by indman@EEVblog).
- Fixed issue in FontTest() with missing spaces for some display drivers.
- Added test output of component symbols (SW_SYMBOL_TEST, suggested by indman@EEVblog).
- Updated Russian texts (thanks to indman@EEVblog).
- Fixed missing ')' character and broken '*' in font_10x16_hf.h (reported by pepe10000@EEVblog).
Please download at:
https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware-
https://github.com/kubi48/TransistorTester-source/tree/master/Markus
