I want to make a nice board for these.
Anyone interested in the bare boards. For the cost of an envelope and international stamp....
Count me in for a couple.
From what I have seen a larger memory, decent resistors, programming header, crystal, battery, external power, backlighting and zif socket are all highly desirable features. As Madires mentioned going with a non standard display can add complexity for no benefit.
I highly recommend going with the display I have pictured, not only are they cheap, easy to source and replace but they look great.
I think the zif socket outside the enclosure works well also like a eprom programmer. Then insert a small pcb into the zif socket for smd devices, or wires for probes etc. Here is my idea I was thinking of, being that you can easily detach the display and it doesn't interfere with the main board.
I was going to make a modular sub board with the zif socket but later decided mounting everything from the zif is better.
![](http://i62.tinypic.com/2wfi88i.jpg)
![](http://i42.tinypic.com/2eulyqg.jpg)
