Author Topic: $20 LCR ESR Transistor checker project  (Read 3949061 times)
wandows, carrascoso, Feliciano and 19 Guests are viewing this topic.
Offline jackryan315
  • Country: ph
« Reply #350 on: April 11, 2014, 12:48:39 pm »
thanks for responding madires.
 im using usbasp as an isp programmer.
Offline madires
  • A qualified hobbyist ;)
« Reply #351 on: April 11, 2014, 12:59:19 pm »
Actually the crystal frequency and the bootloader shouldn't matter because the programmer will set the ATmega to ISP-mode. Have you connected a pull-up resistor to the reset pin? Please post the fuse bits if you're able to read them.
Offline jackryan315
  • Country: ph
« Reply #352 on: April 11, 2014, 01:19:02 pm »
yes a 10k resistor is connected at pin 1 of the atmega328.
here's a screenshot of the gui:
Offline madires
« Reply #353 on: April 11, 2014, 02:06:10 pm »
I can't see any obvious  issue. You could try changing the bit clock for the 8MHz crystal.
Offline jackryan315
  • Country: ph
« Reply #354 on: April 11, 2014, 10:09:11 pm »
how do i go about changing the clock bit?
Offline madires
« Reply #355 on: April 12, 2014, 12:21:56 pm »
The bit clock is the speed the programmer talks to the ATmega. Please see avrdudess in the progammer section, port, baud rate and then bit clock (-B). BTW, -B is the commandline option used for avrdude. You could try to lower the speed. The recommendation is that the ISP clock should not exceed 1/4 of the CPU clock.
Offline jackryan315
  • Country: ph
« Reply #356 on: April 13, 2014, 11:32:53 am »
Hey thanks madires for the guidance. I've managed to build the tester and its awesome.  Its 1.10 version. The different function is cool, again thanks a lot.
Offline eevbstedt
« Reply #357 on: April 13, 2014, 05:04:09 pm »
I see that 1.10k has been moved (added) to the 'Tags' folder:
http://www.mikrocontroller.net/svnbrowser/transistortester/Software/tags/?sortby=date
I'm assuming that this means 1.10k is 'done' and he's now working on 1.11k?
Offline madires
« Reply #358 on: April 13, 2014, 08:02:08 pm »
That's right!
Offline eevbstedt
« Reply #359 on: April 13, 2014, 08:25:53 pm »
This is EXCITING!!!  ... or is it!?   Sooo mysterious!  :D
Offline neslekkim
  • Country: no
« Reply #360 on: April 17, 2014, 05:35:21 pm »
On ebay it seems that there are three other variations that have been developed of this:
http://www.ebay.com/itm/171285924831
http://www.ebay.com/itm/181164691633
http://www.ebay.com/itm/201074091766
According to the description, it seems like it have to be the same, and same firmware, but with some modifications, too bad, as it doesnt seem like there are any upgrade options, or no firmware source available, because the hardware starts to look very interresting.
Offline Hydrawerk
« Reply #361 on: April 17, 2014, 05:49:33 pm »
They look nice, but in fact they do not tell you more.
Offline Hydrawerk
« Reply #362 on: April 17, 2014, 05:54:17 pm »
I prefer this old design with HD44780 compatible LCD, because they are cheap, easy to buy, and they will be probably always available.
Offline g***!
« Reply #363 on: April 17, 2014, 07:13:39 pm »
I have the version, in the second picture in post 361....It arrived today. Its all SMD with an M328P and an unpopulated space for a 10 pin programming header.
Along the top edge of the board is another unpopulated space for a 16 pin header....interesting!
Offline madires
« Reply #364 on: April 17, 2014, 07:40:46 pm »
The 16 pin header might be for a HD44780 display. I don't recommend to buy the Transistor Testers with the graphics display because they require a modified firmware, i.e. you can't use the latest release from the official repo. You'll be reliant on someone in China updating the firmware and I doubt that the source is available publicly.
Offline Shock
« Reply #365 on: April 17, 2014, 08:08:39 pm »
Good point
Offline dannyf
« Reply #366 on: April 17, 2014, 08:27:34 pm »
Good point
The code is fairly well packaged (all in lcd-routines.c/.h). So if you ever need to port it to a different display, you just need to implement your own lcd-routines.c/.h and recompile.
I did it with a nokia 7110 display - which looks to be similar to the graphics lcds shown earlier.
Offline at2marty
« Reply #367 on: April 17, 2014, 08:58:53 pm »
I've read quite a bit about this project and am in the early stages of adapting it with a few minor modifications.  For the most part, most of what I plan will remain the same, but I chose to use an ATMega1284p so that I could do a few other things with it.
Offline jackryan315
  • Country: ph
« Reply #368 on: April 18, 2014, 01:29:51 am »
i've changed my firmware to version 1.7k coz i have no use of the other function just yet. but good to know that its there if ever you need them. BTW, anyone have a link to the writeup of these tester, all versions i mean? I only found two of these which are versions 96k and 107k.
Offline free_electron
    • SiliconValleyGarage
« Reply #369 on: April 18, 2014, 05:30:19 am »
I was looking at these today. Found em on ebay and discovered they were based of the microcontroller.net project and also documented on eevblog.
I want to make a nice board for these, includong the booster for the zeners, the shorting relays to protect the inputs and the other options not commonly found in the wingpangpong versions.
The board must fit a nice handheld box with proper battery holders. I will use either 4 aa cells or go with a rechargeable lithium battery (usb) in which case i awant to add a usb uart.
Now, i do like the graphical display... Anyone has the code for that ? If not i will use the dogm series displays.
I am going to make a connector plate so ican push sot23, sot89 sot 232 and many other smd packages on it to find out what they are.
I will release artwork as public domain and have a bunch of em made by itead so they are cheap.
Anyone interested in the bare boards. For the cost of an envelope and international stamp....
Offline madires
« Reply #370 on: April 18, 2014, 05:50:44 am »
Perfect timing :-) Karl-Heinz has started to work on an  ATmega324/644/1284 version.
The following users thanked this post: elecdonia
Offline madires
« Reply #371 on: April 18, 2014, 05:58:16 am »
You'll find the docs for the old firmware versions at http://www.mikrocontroller.net/svnbrowser/transistortester/Doku/tags/old/english/ and the old firmwares at http://www.mikrocontroller.net/svnbrowser/transistortester/Software/tags/. The current version under development is in the trunk directory and the m-firmware at http://www.mikrocontroller.net/svnbrowser/transistortester/Software/Markus/. To download directories please click "Download GNU tarball" at the bottom.
Offline madires
« Reply #372 on: April 18, 2014, 06:03:29 am »
If you like we could put it into the official repo (there's a hardware section already).
« Reply #373 on: April 18, 2014, 08:41:15 am »
I will nibble for a few boards, then build them up for the local HAM club. that should keep them busy ( and me as well) for a week or three building them. Will pull out the odd displays I have to use there as well.
Offline dannyf
« Reply #374 on: April 18, 2014, 09:50:05 am »
an interesting twist would be to make an arduino-shield that has all the hardware other than the mcu.
