For a nice Easter weekend:
v1.46m
- Added option to disable text based pinout for 3-pin semiconductors when component symbols are enabled (UI_NO_TEXTPINOUT, suggested by bffargo@EEVblog).
- Pin designators for MOSFET's intrinsic diode, IGBT's flyback diode, BJT's flyback diode, BJT's base-emitter resistor and Schottky-clamped BJT's base-collector diode are now also color coded.
- Fixed output of symbol pinout for symmetrical JFETs (shows now 'x' for drain and source).
- Reworked management and output of pin designators for 3-pin semiconductors.
- Updated Romanian texts (thanks to Dumidan@EEVblog).
- Updated font font_8x12t_win1251_vfp.h (thanks to indman@EEVblog).
- Revised component symbols. Removed cycles and added pin designators (suggested by indman@EEVblog). Old symbols can be still used (set SYMBOLS_<size>_OLD_<format>.h in config_<MCU>.h).
- Display probe/testpin IDs with reversed colors (UI_PROBE_REVERSED, suggested by Feliciano@EEVblog).
- Added numbers 1-3 with reversed color to several fonts (thanks to Feliciano@EEVblog).
- Updated Russian texts (thanks to indman@EEVblog).
- Updated Spanisch texts (thanks to pepe10000@EEVblog).
- Updated Polish texts #2 (thanks to Jacon@EEVblog).
Please download at:
https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware-
https://github.com/kubi48/TransistorTester-source/tree/master/Markus
