I bought one of these tester via eBay, but the LCD display does not seem to have back-lighting. The tester's main PC board is labeled "Ver 2.4 2013/07/01"; the PC board holding the LCD display is labeled "Zijing Electronics". Pads 15 and 16 on the display PC board are unused (no pins attached), but these two solder pads do have traces connected to them (hard to trace the connections -- no schematic, solder mask, etc.). Does anyone know whether back-lighting on this tester's LCD module can be enabled? If so, how? Also, would the 25-50mA or so for the back-light LEDs be too much for the 5V regulator? Any help would be appreciated!
John
