Author Topic: $20 LCR ESR Transistor checker project  (Read 3909493 times)
indman and 32 Guests are viewing this topic.
Offline ko4nrbs
« Reply #6925 on: May 28, 2021, 01:50:57 pm »
The back light does not come on.  Thanks for the schematic!!
Bill
Offline madires
  • A qualified hobbyist ;)
« Reply #6926 on: May 28, 2021, 02:03:25 pm »
And the LED (right of the battery connector)?
« Last Edit: May 28, 2021, 02:05:01 pm by madires »
Offline ko4nrbs
« Reply #6927 on: May 28, 2021, 02:08:38 pm »
Is Transistor T1 a 2SA673?  I can't see the text on the schematic very well.  Couldn't find it's pin out.  It has 9vdc on the two contacts that are on the same side to the single contact on the other side.
Bill
Offline ko4nrbs
« Reply #6928 on: May 28, 2021, 02:10:23 pm »
The LED does not light up either.
Bill
Offline madires
« Reply #6929 on: May 28, 2021, 02:15:37 pm »
Yep, T1 can by any jelly bean PNP with an hFE of around 250 or higher. Do you get 5V at the output of the voltage regulator IC1 when pressing the test button?
Offline ko4nrbs
« Reply #6930 on: May 28, 2021, 02:26:17 pm »
Checked all three contacts on IC1 to the GND contact on the other side and to each other.  No output voltage when pressing the test button.  Also checked both sides of C4 with no voltage see while pushing button.
Bad IC1??
Bill
Offline madires
« Reply #6931 on: May 28, 2021, 02:31:33 pm »
And also no input voltage (battery)? Then it could be a bad T1.
Offline ko4nrbs
« Reply #6932 on: May 28, 2021, 02:35:57 pm »
Both the contacts on T1 that are on the same side read 9vdc to GND.
Bill
Offline Yuriy_K
  • Country: ru
« Reply #6933 on: May 28, 2021, 02:38:02 pm »
Change T1, I changed mine twice, until I replaced it with a larger body ...
Offline ko4nrbs
« Reply #6934 on: May 28, 2021, 02:42:14 pm »
No voltage on either side of C10 or R20.  Must be T1.  What transistor did you use?
Bill
Offline Yuriy_K
  • Country: ru
« Reply #6935 on: May 28, 2021, 03:34:25 pm »
PNP S9012  hFE=227.
Offline ko4nrbs
« Reply #6936 on: May 28, 2021, 03:49:58 pm »
Can I use a TO92 pin type instead of a SMD 2T1 type?
Bill
Offline Yuriy_K
  • Country: ru
« Reply #6937 on: May 28, 2021, 04:00:17 pm »
yes,  Ic (mA) = 500, OK!
Offline ko4nrbs
« Reply #6938 on: May 28, 2021, 04:03:01 pm »
I ordered 50 SMD type.  If I screw up I have plenty of extras!!
Thank you for the assistance!!
Bill
Offline Yuriy_K
  • Country: ru
« Reply #6939 on: May 28, 2021, 04:11:55 pm »
Of course, the location allows
Offline madires
« Reply #6940 on: May 28, 2021, 05:35:34 pm »
In case of through-hole the BC328-40 (I_C -800 mA) is a good choice.
Offline Yuriy_K
  • Country: ru
« Reply #6941 on: May 28, 2021, 05:44:36 pm »
No, there is a two-sided mounting without pass-through holes.
Offline madires
« Reply #6942 on: May 28, 2021, 06:51:29 pm »
The SMD equivalent (SOT-23) would be a BC808-40.
Offline Yuriy_K
  • Country: ru
« Reply #6943 on: May 29, 2021, 10:26:57 am »
Ttesters with installed software Karl-Heinz Kübbeler 1.13k, after minor alterations, can test IGBT transistors. Everything in the picture ...
Checked out similar add-ons for ComponentTester-1.43m. With insufficient gate voltage, an additional battery allows you to get readings ...
« Last Edit: June 02, 2021, 07:33:31 am by Yuriy_K »
The following users thanked this post: madires, edgard22
Offline ko4nrbs
« Reply #6944 on: June 01, 2021, 10:33:24 pm »
Bill
New transistor fixed it!!
Thank you.
Bill
Offline Andbro
« Reply #6945 on: June 03, 2021, 11:03:18 pm »
Hi    Yuriy_K,
With the new GM328A model with a MCU for the display, i load by USBASP your firmware and it's over ?
Thank
Offline Yuriy_K
  • Country: ru
« Reply #6946 on: June 04, 2021, 03:19:40 am »
Your model differs from those Ttesters, which were used for debugging and adjusting the color gamma. Without seeing the back side of your display, i cannot determine the RGB or BGR gamma ...
Offline Andbro
« Reply #6947 on: June 04, 2021, 08:52:19 am »
Hello Yuriy_K ,
Probably my display is BGR. After changed the frequency for 8Mhz, it's impossible to WINAVR MAKE ALL".
I have always 2 errrors.
One warning for CPU   unsigned long wish_freq;   // frequency (Hz), which you want to create
../Obj/ST7735_BGR/PinLayout.o: In function `ldata_ipp':
(.text+0x94): relocation truncated to fit: R_AVR_13_PCREL against symbol `lcd_data' defined in .text.lcd_data section in ../Obj/ST7735_BGR/lcd-routines.o
make.exe: *** [../Obj/ST7735_BGR/ST7735_BGR.elf] Error 1
thank
Offline Yuriy_K
  • Country: ru
« Reply #6948 on: June 04, 2021, 10:36:35 am »
Why are you trying to create your own firmware? You won't succeed !!! My sources are very different from the Author's.
You can only install my finished firmware using AVRDUDE ...
Added to the message on the previous page ST7735_RGB_en_8MHz.zip, sorry did not notice ...
« Last Edit: June 04, 2021, 11:42:26 am by Yuriy_K »
Offline Andbro
« Reply #6949 on: June 04, 2021, 12:20:03 pm »
Hi Yuriy_K,
I have questions:
- What is the difference between the firmware ST7735_BGR_en and ST7735_BGR_en1?
- The Vext is not available ?
- How work the f-Generator ?
- How can i modified battery voltage display (Display 8.15V, Real 8.9V)
- How change the rotation menu ?
Thank
