Hi.
They gave me a GM328 that they broke when measuring a charged electrolytic capacitor. The SVR05-4 was shorted, and the Atmega was bad too.
I removed the SVR05-4 and the P6KE6V8A since they are not necessary for the proper functioning of the meter, and I programmed another Atmega at 20Mhz (and tested with several) and also changed the Xtal to 20Mhz.
Now it turns on smoothly, but it doesn't work properly.
When I turn on the meter without any components in the measurement socket, it should indicate that there are no components.
Well, it indicates that there are high value resistors or high value capacitors connected.
With normal use of the meter I put components in the socket and except for the capacitors all other components seem to measure well.
The same happens with firm M and firm K, so it is a meter problem.
E measured continuity from the 3 points where the component to be measured is placed to pins 23-24-25 of the Atmega.
From those 3 same points to pins 14-15-16-17-18-19, checking that the resistors are good.
7550 output voltage when measuring component, stable 4.97V.
TL431 output voltage, 2.48V stable.
I would appreciate a help. Thank you
