AlcidePiR2
I suggest you make the same measurements on k-firmware 1.13k and compare the results. ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
This is done with the I.13k
with the following changes in the autoconf.h because the resistors I had in 0.1% accuracy were not the 680/470k standards.
/* check the R_L_VAL and R_H_VAL setting */
#ifndef R_L_VAL
#define R_L_VAL 6810 // standard value 680 Ohm, multiplied by 10 for 0.1 Ohm resolution
#endif
#ifndef R_H_VAL
#define R_H_VAL 47500 // standard value 470000 Ohm, multiplied by 10, divided by 100
#endif
The results are comparable. Maybe slightly better
679.6
474.5
99.3
10.01-2 k (variations in a sequence of measures)
999.4-8 k (variations in a sequence of measures)
