Author Topic: $20 LCR ESR Transistor checker project  (Read 3966112 times)
CaptainBucko and 33 Guests are viewing this topic.
Offline madires
  • A qualified hobbyist ;)
« Reply #6075 on: January 03, 2020, 02:23:56 pm »
Only remaining thing to do is remove the TL431?  Its firmware 1.13k.  I only ask because the TL431 is very close to the socket for the Mega328.  I think it would be easy to remove but VERY hard to solder back in, at least using a soldering iron.  Do I need to reprogram the AVR or does it autodetect the presence of the 431?
The k-firmware auto-detects the external 2.5V reference by default. IIRC, there's no configuration switch to disable the code for the external reference.
The following users thanked this post: petert
Offline hpmaxim
« Reply #6076 on: January 03, 2020, 02:39:11 pm »
The documentation I saw suggested that if the voltage reference was removed you should install a 47k resistor (R16) pull-up onto the cathode pin.  The board I have, has values but not component designators.  I suppose if this is the case an 0805 resistor could probably fit between the terminals, since I think one terminal of the TL431 is hooked to VCC.
Interestingly, from what I can tell the MCP1702 guarantees only 0.4% accuracy, whereas the LM4040A should be accurate to 0.1%, while the TL431 is accurate to 0.5-2% depending on which one is used.  I'm a little surprised why the LM4040A isn't recommended.  Unfortunately, the pinout appears to be different, and it seems to require a pull-up of ~39K.
Offline timelessbeing
« Reply #6077 on: January 05, 2020, 10:29:59 am »
I think it goes without saying that Chinese clones will come with the lowest grade reference.
You don't really need to know the R designator. As the readme says, if the program doesn't detect the missing reference, just increase the value of the pull-up resistor on pin PC4.
The LM4040 was mentioned a couple times in the readme, as well as other alternatives.
Offline madires
« Reply #6078 on: January 05, 2020, 11:51:09 am »
From testing different voltage references we found out that the external 2.5V reference needs to be about 10 times more accurate than the voltage regulator to provide a benefit. As an alternative you could measure Vcc with a proper bench DMM and adjust the configuration value accordingly.
Offline daemon123
  • Country: pk
« Reply #6079 on: January 06, 2020, 08:44:06 pm »
No change, still dead slow
avrdude -c avrisp -b 19200 -p m328pb -P COM7 -U flash:w:TransistorTester.hex:a -U eeprom:w:TransistorTester.eep:a -v
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean, [url]http://www.bdmicro.com/[/url]
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : avrisp
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328PB
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel AVR ISP
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9516 (probably m328pb)
avrdude: safemode: lfuse reads as E2
avrdude: safemode: hfuse reads as D9
avrdude: safemode: efuse reads as F4
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "TransistorTester.hex"
avrdude: input file TransistorTester.hex auto detected as Intel Hex
avrdude: writing flash (29732 bytes):
Writing | ################################################## | 100% 33.30s
avrdude: 29732 bytes of flash written
avrdude: verifying flash memory against TransistorTester.hex:
avrdude: load data flash data from input file TransistorTester.hex:
avrdude: input file TransistorTester.hex contains 29732 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 19.14s
avrdude: verifying ...
avrdude: 29732 bytes of flash verified
avrdude: reading input file "TransistorTester.eep"
avrdude: input file TransistorTester.eep auto detected as Intel Hex
avrdude: writing eeprom (857 bytes):
Writing | ################################################## | 100% 42.31s
avrdude: 857 bytes of eeprom written
avrdude: verifying eeprom memory against TransistorTester.eep:
avrdude: load data eeprom data from input file TransistorTester.eep:
avrdude: input file TransistorTester.eep contains 857 bytes
avrdude: reading on-chip eeprom data:
Reading | ################################################## | 100% 3.46s
avrdude: 857 bytes of eeprom verified
avrdude: safemode: Fuses OK (E:F4, H:D9, L:E2)
avrdude done.  Thank you.
will try to install another crystal tomorow,
could it be a bad chip ?
or the firmware is not for 8mhz ?
Referring to my old post, i got the LCR T4 working with m328pb. For some reason it was on clock failure detection swtching to 1mhz and i was unable to set the correct fuse to disable CFD.
Here are the correct fuses for ATmega 328pb
efuse = FC
hfuse = D9
lfuse = FF
the default avrdue.conf will not write the correct efuse FC
you have to modify the avrdude.conf
open it and ATmega328 look for 'memory "efuse"' section. It will look like below
    memory "efuse"
size = 1;
min_write_delay = 4500;
max_write_delay = 4500;
read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
       "x x x x x x x x o o o o o o o o";
write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
      "x x x x x x x x x x x x x i i i";
change
to
"x x x x x x x x x x x x i i i i"
      "x x x x x x x x x x x x i i i i";
Save it, now u will be able to program the correct efuse FC.
Now i have some questions. Can i install rotary encoder in this variant ?
also is m-firmware (compiled) available for it ?
any other mods for it ?
Offline madires
« Reply #6080 on: January 07, 2020, 01:44:31 pm »
Thanks for the hint! A rotary encoder should be possible (try PD1 and PD3), but you need to configure and compile the firmware for that.
The following users thanked this post: daemon123
Offline pepe10000
Offline Andbro
« Reply #6082 on: January 10, 2020, 11:47:10 pm »
I have a colour T7 model. It's the same model as the TC1, i think so. I have read the file in Clones in Markus firmware 1.38. My question is: is it possible to replace the firmware without removing the U4 Micro-controller STC15L104W ? My display has 6 pins.
Thanks
Offline madires
« Reply #6083 on: January 11, 2020, 11:31:06 am »
You could reprogram U4 (https://github.com/atar-axis/tc1-u4). That firmware was tested with the TC-1 but I assume it should also work with with the other models.
Offline Andbro
« Reply #6084 on: January 11, 2020, 09:38:00 pm »
When i "Make All" with WinAVR, i have this error. Firmware Markus for TC7.
main.c: In function 'CheckBattery':
main.c:1392:21: warning: unused variable 'Temp' [-Wunused-variable]
Thank for your help
Offline standal
  • Country: cz
« Reply #6085 on: January 11, 2020, 10:13:03 pm »
Hello,
is it possible to use frequency counter on anothet input pin? PD4 is used at LCR-T4 as reset pin for display and therefore is not possible to use this feature. Can somebody modify m-firmware or tell what and how to modify? In source I have read that it has to be PD4.
Thanks
standal
Offline madires
« Reply #6086 on: January 12, 2020, 12:56:45 pm »
It's just a warning you can simply ignore. Will be fixed in the next firmware version.
The following users thanked this post: Andbro
Offline madires
« Reply #6087 on: January 12, 2020, 01:21:21 pm »
The frequency counter uses hardware timer #0 for counting pulses. Timer #0's fixed input is T0 which is PD4 (ATmega328). Your best bet is to disconnect the displays reset line from PD4, to use a pull-up resistor and cap to create a reset pulse and to disable LCD_RESET in the display's configuration.
Offline standal
  • Country: cz
« Reply #6088 on: January 12, 2020, 02:10:05 pm »
thank you for advice, but I wanted to avoid HW modifications. But would not be possible to use timer 1 (PD5)? This one is not used on the LCR-T4.
Offline madires
« Reply #6089 on: January 12, 2020, 03:32:23 pm »
Timer #1 is already used for the gate time.
Offline standal
  • Country: cz
« Reply #6090 on: January 12, 2020, 04:40:31 pm »
and is not possible to use timer#0 for "the gate time" and than timer#1 for frequency counter?
Offline madires
« Reply #6091 on: January 12, 2020, 05:16:52 pm »
Timer #0 is an 8-bit timer, while Timer #1 is 16 bits. And the firmware doesn't have an abstraction layer to deal with multiple sources triggering the same interrupt.
« Last Edit: January 12, 2020, 05:23:30 pm by madires »
Offline alxtr1bal
« Reply #6092 on: January 29, 2020, 06:05:02 am »
Hello everyone,
Has anyone succeeded in installing the latest 1.13k-firmware on the clone LCR-T7 (m324pa mcu)  ?
I modded the u4 firmware , and used the ST7735 Makefile, mcu = m644, compiles ok. Then i use my TL866 II programmer (fuses set there).
After upload on the device, start, the screens stays blank...
I would appreciate if someone could help me on this :-)
I managed to compile and install the 1.38m successfully, but i wanted to try the k one !
Thank you  :)
Offline madires
« Reply #6093 on: January 29, 2020, 01:58:07 pm »
Have you set "PARTNO = m324p" in the Makefile?
Offline indman
  • Country: by
« Reply #6094 on: January 29, 2020, 02:21:37 pm »
Hello everyone,
Thank you  :)
K-firmware requires major changes to source files in order to customize firmware for clone LCR-T1 (T7). :( In m-firmware, this is done much easier and faster(thanks madires!)
Offline alxtr1bal
« Reply #6095 on: January 29, 2020, 07:34:22 pm »
Hello @madires, yep, but in config.h, it's considered like 644.
Offline alxtr1bal
« Reply #6096 on: January 29, 2020, 07:35:20 pm »
Hello everyone,
Thank you  :)
I think so too.
Offline madires
« Reply #6097 on: January 29, 2020, 09:05:45 pm »
Does the tester stay powered on for a few seconds (backlight lit) after pushing the start/test button?
Offline alxtr1bal
« Reply #6098 on: January 30, 2020, 06:20:11 am »
My last test (after playing with some defines) shows that the screens stays on, i can't power it off.
But i can remember that i had the screen stays on a few seconds yes... can't remember the defines... i did a lots of testing.
Offline madires
« Reply #6099 on: January 30, 2020, 12:35:00 pm »
In that case there's something wrong with the pin assignment for the display signal lines.
