Author Topic: $20 LCR ESR Transistor checker project  (Read 3835838 times)
Offline madires
  • A qualified hobbyist ;)
« Reply #5825 on: August 23, 2019, 08:52:28 am »
Have you done the self-adjustment? And to have the result stay on screen start the tester with a long key press or enable UI_AUTOHOLD. Please see the README for details.
Offline SirAlucard
« Reply #5826 on: August 23, 2019, 04:50:17 pm »
Yea I figured it was the AutoHold, and got that going, but it's actually the self adjustment that does it. So at first start of a fresh flash things work as they should, minus large capacitor amounts shutting the thing down, it still does that. However I found out that if I run the adjustment option, after it's done is when it thinks there is a 22-32pF capacitor across 1-2, also for some reason 2-3 doesn't want to recognize a component connected to it. Or for that matter 1-3. The firmware that I tried using after editing my own configs was the one listed by indman here. Listed under M328kit+TFT. It still does that.
Offline madires
« Reply #5827 on: August 23, 2019, 05:46:02 pm »
Very strange! Maybe a different pin assignment (tester and firmware don't match)?
Offline SirAlucard
« Reply #5828 on: August 23, 2019, 06:17:44 pm »
The other odd thing is while it doesn't recognize a component connected from 1 to 3, or 2 to 3, it does successfully recognize a PNP Transistor, and a NPN Transistor. As well as mosfets for that matter. So I don't know whats going on.
Offline indman
  • Country: by
« Reply #5829 on: August 23, 2019, 08:15:25 pm »
SirAlucard,madires
I in such problem cases ask to publish results of hardware T1-T7 tests - it in many respects helps to define a problem source. Do you agree? :)
Offline madires
« Reply #5830 on: August 23, 2019, 08:48:41 pm »
I do! ;D
Offline 001
  • Country: aq
« Reply #5831 on: August 26, 2019, 11:58:28 am »
What most progressive TT model for 2019?
Offline madires
« Reply #5832 on: August 26, 2019, 01:26:55 pm »
Please enter the menu, run the "test" and post the results.
Offline madires
« Reply #5833 on: August 26, 2019, 01:37:20 pm »
An AY-AT clone or maybe the Hiland M644 (comes with the extended frequency counter). But for the real fancy stuff you still have to build one yourself.
The following users thanked this post: petert
Offline noremac13
« Reply #5834 on: August 29, 2019, 06:55:29 pm »
So I just ordered one of these expecting to use it for troubleshooting capacitors in-circuit but it doesn't seem to work right for that. Maybe I am doing something wrong? It is returning capacitance values that are 3x, 5x, even 10x what is printed on the cap.
Offline madires
« Reply #5835 on: August 29, 2019, 08:02:52 pm »
That is to be expected since there's circuitry in parallel with the cap.
Offline noremac13
« Reply #5836 on: August 29, 2019, 09:48:07 pm »
But I thought the whole point of LCR/ESR meters was their ability to test components while they are still in the circuit?
Offline Andbro
« Reply #5837 on: August 29, 2019, 11:20:13 pm »
I have bought a new AY-AT. When i'm calibrate, the values R0= 0.62, 0.64, 0.63
I found these values very high or it's normal ?
Thank
Offline bitseeker
« Reply #5838 on: August 30, 2019, 02:49:23 am »
Afraid not. That would be quite a device if it could figure out the topology of the circuit, identify the components that are interacting with the one being measured, interpret the behavior of said topology and components, and then infer what the correct value should be rather than the value that is measured.
As a simple example, if you're given a black box with two terminals to measure the capacitance inside, how can you tell how many capacitors there are without looking in the box? You can measure the total capacitance value, but that could be the result of one or a dozen capacitors. Suppose that you open the box and find that there are five capacitors in parallel. How do you measure the value of the middle capacitor? What about the left-most one?
The only reliable way to measure an individual component is to do it in isolation. In-circuit measurement can be useful if you understand the circuit, what you're measuring, and what you're not measuring, in order to get an idea what may be faulty. Then, you confirm your hypothesis by re-measuring out of circuit.
Offline casinada
« Reply #5839 on: August 30, 2019, 05:31:49 am »
The Hiland Tester with the ATMEGA 644 is down to $16. Time to buy?? :-//
https://www.aliexpress.com/item/32912063006.html?spm=a2g0s.8937460.0.0.816c2e0eN7mWyo
Offline SirAlucard
« Reply #5840 on: August 30, 2019, 07:48:31 am »
It doesn't really give me values at the end of it, unless I'm suppose to go to the values section in which case these are what is listed below.
Ri- 20.0Ω
Ri+ 22.0Ω
C0 43pF
R0 0.20Ω
Vref 1096mV
Vcc 5013mV *
AComp 0mV
SirAlucard,madires
What are the hardware T1-T7 tests?
Offline silvestrogatto
« Reply #5841 on: August 30, 2019, 08:01:37 am »
I have a GM328 (red PCB) Transistor Tester with ST7735 display (pls see attached picture)
I am looking for the original 1.12k firmware.
Is there anyone who made a copy of the original 1.12k firmware that can send me .hex and .eep files?
Thank you!
s.g.
The following users thanked this post: elecdonia
Offline madires
« Reply #5842 on: August 30, 2019, 08:06:50 am »
The test function runs several checks (T1...), each check is done 5 times. Note the results (second line) once for each check. It's explained in the README.
Offline indman
  • Country: by
« Reply #5843 on: August 30, 2019, 08:20:06 am »
Original mod chinese firmware 1.12k it is locked for read!
« Reply #5844 on: August 30, 2019, 08:32:12 am »
Thank you indman for your prompt reply.
I tried different FW (both compiled and to compile) but no one has the same features of the original one and, even going thru all the changes and settings, I cannot get a 100% hardware compatible and stable firmware running on my tester.
Is there any specific version you recommend for my TT model? Thanks!
Offline Andbro
« Reply #5845 on: August 30, 2019, 10:14:02 am »
Thank
Offline madires
« Reply #5846 on: August 30, 2019, 10:16:11 am »
It's an AY-AT clone. If you like to use the k-firmware please try mega328_color_kit from the repo.
The following users thanked this post: silvestrogatto
Offline madires
« Reply #5847 on: August 30, 2019, 10:24:08 am »
My testers with a ZIF socket have around 0.2 Ohms usually. Have you measured a film cap (220-2200nF) three times before running the self-adjustment?
Offline Andbro
« Reply #5848 on: August 30, 2019, 11:28:28 am »
Hi madires,
I have not try to measure film cap before calibration. Now it's done, but i have again a high values, but the accuracy is good.
Is't possible my encoder has a resistor value ?
Thank
Offline madires
« Reply #5849 on: August 30, 2019, 12:31:28 pm »
Encoder? Are you using a rotary encoder to short the probes?
