MasGanBro,try to use an firmware which I have attached in archive.
What will be on the display? Check whether there is power + 5.0B on the 4-6(VCC) th pin of the ATMega328 processor. For check that the firmware works you can insert into the ZIF panel on contacts 1-3(1-2,2-3) any serviceable light-emitting diode - when pressing the Test button it has to blink.
Microsoft Windows [Version 10.0.17134.165]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\Users\hore>cd C:\Users\hore\Downloads\Anto\LCR-T4NoStripGridRev798
C:\Users\hore\Downloads\Anto\LCR-T4NoStripGridRev798>FlashK.bat
C:\Users\hore\Downloads\Anto\LCR-T4NoStripGridRev798>REM Writing Flash + EEPROM + Fuses (L=F7, H=D9, E=04)
C:\Users\hore\Downloads\Anto\LCR-T4NoStripGridRev798>avrdude -c avrisp -p m328p -P COM4 -b 19200 -e -U flash:w:"TransistorTester.hex":a -U eeprom:w:"TransistorTester.eep":a \-U lfuse:w:0xF7:m \-U hfuse:w:0xD9:m \-U efuse:w:0x04:m
'avrdude' is not recognized as an internal or external command,
operable program or batch file.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x00ff00
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done. Thank you.
avrdude: Device signature = 0xff00ff
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file "TransistorTester.hex"
avrdude: input file TransistorTester.hex auto detected as Intel Hex
avrdude: writing flash (30064 bytes):
Writing | ################################################## | 100% 33.51s
avrdude: 30064 bytes of flash written
avrdude: verifying flash memory against TransistorTester.hex:
avrdude: load data flash data from input file TransistorTester.hex:
avrdude: input file TransistorTester.hex contains 30064 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 19.06s
avrdude: verifying ...
avrdude: 30064 bytes of flash verified
avrdude: reading input file "TransistorTester.eep"
avrdude: input file TransistorTester.eep auto detected as Intel Hex
avrdude: writing eeprom (871 bytes):
Writing | ################################################## | 100% 42.78s
avrdude: 871 bytes of eeprom written
avrdude: verifying eeprom memory against TransistorTester.eep:
avrdude: load data eeprom data from input file TransistorTester.eep:
avrdude: input file TransistorTester.eep contains 871 bytes
avrdude: reading on-chip eeprom data:
Reading | ################################################## | 100% 3.48s
avrdude: 871 bytes of eeprom verified
avrdude: safemode: Fuses OK (E:FC, H:D9, L:F7)
Whoa. She revive
v1.13k
Big Thanks Mr Indman
and honestly, still confused to use. And font too big
Im more simple guy, put in socket and press button.
but i can learn new habits. Hehehe
Thank you Sir. Thank you
===add edit===
Im sorry, i think must hold/long press to measure, like first turn on.
turns out, still just click.
and for same component in sequence, said resistor
we can put in socket and that auto measure, remove, then put next item, auto measure
is that?
tester not wrong again about jfet and can measure small ceramic value. i like it!
but, this happen when test jfet
for me, its okay, still see pin in picture
Sorry, i dont know why became portrait
for mosfet, 'normal'
End of morning news.
