Hello guys.
"SALAM" form Indonesia.
Let me share my job testing for last version ESR from Karl-Heinz trunk on proteus 8.7 sp2
with ST7735 lcd.
This project based from old trunk KH esr files for ST7565 from this post.
You can find the original works here.
http://kazus.ru/forums/showthread.php?t=8259&page=20#Schematic is very simple and not full like real board.
REMEMBER !!! its made just for test only on proteus.
you can change whatever you want for simulation, but must be
warning if execution on real HW.
I change some parameter on makefile and not connected all of lcd pin on proteus to make its displayed and works on proteus.
I change "
MAX_MENU_LINES" from 5 to 14 menu in
"function_menu.c" in this test.
Remember to change the parameter if you want to flash in real hardware before compile it.
uncomment
#CFLAGS += -DUSE_EEPROM in makefile if compile for real HW.
If anyone has same project from Markus based esr, and works displayed on proteus with BW/Color lcd, please share it, because still now i got not working simulation for Markus based esr.
Finally.... I hope you like, and forgive for my bad English.
