Author Topic: $20 LCR ESR Transistor checker project  (Read 3907322 times)
valcher, Melt-O-Tronic, tedris, Fuzzy Star and 13 Guests are viewing this topic.
Offline madires
  • A qualified hobbyist ;)
« Reply #4725 on: May 10, 2018, 08:57:07 pm »
There's a known bug when using the discharge/protection relay and a rotary encoder. It's already fixed in the new version under development.
Offline timelessbeing
« Reply #4726 on: May 10, 2018, 09:13:22 pm »
 :-+ great.
It looks like you don't post code changes, only releases. And no bug tracker. Is this the case?
Offline joeyjoejoe
« Reply #4727 on: May 10, 2018, 11:24:29 pm »
Picked one of these up, hoping to flash it to the latest version as well as replace it with some better resistors. Has anyone seen this variant?
Single sided board, 128x160 Color display.
Not sure if it's allowed to post a link to the seller, but the description was "Multi-purpose Transistor Tester 128*160 Diode Thyristor Capacitance Resistor Inductance MOSFET ESR LCR Meter TFT Color Display".
On bootup, it has a custom firmware by weiweitm and a link to their taobao site.
I soldered a header on, the AVR is locked of course, so I can't dump the firmware to just give it a shot. I browsed the subversion repo and google'd all the different display variants but didn't notice one that would be appropriate for this one.
« Reply #4728 on: May 10, 2018, 11:54:35 pm »
In the "Markus" firmware, you can select your hardware options in config_328.h
Find out what chip drives the display, and enable that header in the code.
Compile from source.
Offline madires
« Reply #4729 on: May 11, 2018, 10:01:53 am »
Yes and yes. But I document the bug fixes in the CHANGES file.
Offline madires
« Reply #4730 on: May 11, 2018, 10:12:12 am »
That tester seems to be a basic one with a ST7735 display. When the default pin assignment doesn't work check out the pin wiring and change the pin assignment accordingly. If you got it working please send me the configuration changes and I'll add them to the sample config for clones. I'd guess the OFF button is connected to PC6 (Reset). It could be possible that your tester has a power circuitry similar to the Fish8840 which has a design flaw draining the battery via the voltage divider for the battery monitoring when switched off. This is explained in Karl-Heinz' documentation, also including a simple fix.
« Last Edit: May 11, 2018, 10:24:39 am by madires »
Offline indman
  • Country: by
« Reply #4731 on: May 11, 2018, 05:01:27 pm »
Hi, everybody! :)
At the Russian-speaking forum vrtp.ru we call this device as Fish8840TFT!
The participant of the forum bdk100 who owns such tester provided the schematic diagram(spl format) and the file of a configuration for madires firmware. I attach these files to the message.
This clone has some features which complicate compilation of own firmware.
1. Resolution of the display - 160х128, but the front frame superimposes a part of the image therefore it is necessary to move and offset the picture a little.
2. The LDO at 3.3V  from power which the display - very not reliable and ceases to work in case of connection of the programmator. Therefore it is recommended to disconnect or unsolder it before programming of the processor.
Offline joeyjoejoe
« Reply #4732 on: May 11, 2018, 07:50:14 pm »
Thanks! It looks like indman provided the configuration needed. Perhaps a mega328_fish8840_TFT directory could be made for this variant?
Could someone confirm my steps? First time flashing this.
1. I've downloaded https://github.com/svn2github/transistortester/blob/master/Software/Markus/ComponentTester-1.32m.tgz
2. Used the config_328.h that indman so nicely provided :)
3. Reviewed some of the config.h values, but only disabled a few things (PWM, signal gen)
Compiling it with avr_gcc, no errors, I have a hex file. Good to flash?
« Last Edit: May 11, 2018, 08:24:34 pm by joeyjoejoe »
Offline HighMans
« Reply #4733 on: May 12, 2018, 12:12:14 am »
Hello all! This is a really long thread, and I don't exactly know where to start, but I've three questions.
1. What would be the reason as to why my component tester is showing 15-18v as the battery voltage instead of the 9v's from the 9v battery? This is the particular kit I bought, but I reckon it's all the same.
2. How do I go about upgrading this kit to the custom firmware that's around on the internet? I'm at version 1.12k currently.
« Last Edit: May 12, 2018, 01:20:04 am by roadran422 »
« Reply #4734 on: May 12, 2018, 01:36:29 am »
Sounds like you mixed up some resistors. Double check the schematic.
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg810893/#msg810893
You might try a search next time.
if I go to the selection menu and select selftest, it works fine. What've I done wrong?
I recommend you read the firmware Readme
The following users thanked this post: HighMans
Offline HighMans
« Reply #4735 on: May 12, 2018, 02:05:51 am »
I looked at the resistors according to the assembly instructions provided to me and all of them do seem to be in place correctly.
Thanks for the link to the firmware, I tried clicking the search button on this forum thread but the results came up empty.
Finally, I figured out the selftest issue -- pebcak error as always. :P
Thanks again!
« Reply #4736 on: May 12, 2018, 02:46:54 am »
What do you have on PC5?
Offline HighMans
« Reply #4737 on: May 12, 2018, 03:02:57 am »
PC5? I don't see that on the silkscreen.
« Reply #4738 on: May 12, 2018, 03:30:56 am »
pin 28 on the atmega
Offline HighMans
« Reply #4739 on: May 12, 2018, 04:10:20 am »
Wow. Looks like I ripped out the connection for that pin on the IC Socket. I'm going to have to get a new one. Thanks for the help!
Offline JonnieCache
« Reply #4740 on: May 12, 2018, 01:30:10 pm »
I’ve done that before. They come out sometimes, but you can put it right back in. When you solder it, it will work just fine!
Offline HighMans
« Reply #4741 on: May 12, 2018, 02:55:35 pm »
That'd be fine if it wasn't for the fact that it's long gone now! I "fixed" it by cleaning out the solder, and sticking in a solid wire to make a connection -- works well enough :P
Offline joeyjoejoe
« Reply #4742 on: May 12, 2018, 03:46:05 pm »
Totally fried this thing :)
I removed it, and now I can program (haven't yet), but the display is also working?! If the 3v3 is supplying power, with that removed, I'm not sure how this is possible based on that schematic....
« Last Edit: May 12, 2018, 03:58:04 pm by joeyjoejoe »
Offline joeyjoejoe
« Reply #4743 on: May 12, 2018, 05:09:13 pm »
To set the proper offset for FISH8840_TFT, find in ST7735.c:
#ifdef LCD_ROTATE
  /* swap X and Y */
  #define LCD_PIXELS_X        LCD_DOTS_Y
  #define LCD_PIXELS_Y        LCD_DOTS_X
  #ifdef LCD_OFFSET_X
    #define LCD_SHIFT_Y       3     /* shift y by 4 dots */
  #endif
  #ifdef LCD_OFFSET_Y
    #define LCD_SHIFT_X       1     /* shift x by 2 dots */
  #endif
#else
Offline Argiros
« Reply #4744 on: May 13, 2018, 07:18:28 am »
Well I finally did it. I follow the schematic and found the PD1 and PD3 pins from the CPU which in my case goes to R21 and R22  10K resistors (SMD 103) and they connect to A0 and SDA LCD pins respectively, for my Display ST7735 although in Karl's doc it says RS and SI for ST7565. So one can solder BEFORE the resistors or else it wont work. I pulled out the selection button and place in his place the rotary and it works perfectly! Better than the other which came with his build in rotary encoder. The only catch is that it powers on with the other reset button and when I put in power it opens automatically. Maybe I miss something from the other side of the circuit in the selection button. Now it is a usefull device, and I dont know why they designed it with only two buttons reset and select, when there are menus , choices etc. Now I can play with the software to make it work as I want, for ex the display I want it rotated in landscape and not portrait. Thank you madires and all the other friends who helped me.
<Argiros>
Can I add a rottary switch button to this model GM328B ? Where I can solder this ?
or else can I add 3 more buttons for using them for scrolling up down and for back ?
<madires>
You can use two push buttons for up/down (increase/decrease) instead of a rotary encoder (k-firmware: WITH_ROTARY_SWITCH 4, m-firmware: HW_INCDEC_KEYS, and check the portpins). The test button is mandatory, either as a separate push button or integrated in the rotary encoder. And there's no back button. As timelessbeing already has mentioned, the wiring is explained in Karl-Heinz' documentation.
« Reply #4745 on: May 14, 2018, 03:34:18 am »
I'm trying to put the Karl-Heinz firmware on my "M328" tester
I tried the firmware from all these folders which seemed relevant:
mega328_GM328
mega328_st7565
mega328_st7565_kit
But the display turned out upside down and backwards each time. Also the rotary encoder didn't work. So I guess I'll have compile from source.
Does anybody know where these options are configured? The KH code is much more difficult to follow, than MR's.
Offline mauroh
    • Mauro Pintus
« Reply #4746 on: May 14, 2018, 10:10:15 am »
I have the same variant. The mega328_st7565_kit folder is the correct one.
I didn't try the latest build, but you shouldn't need to modify anything, it should just works.
If not try different combinations of the following settings in the Makefile
CFLAGS += -DLCD_ST7565_H_FLIP=0
CFLAGS += -DLCD_ST7565_V_FLIP=1
Mauro
The following users thanked this post: timelessbeing
Offline mauroh
    • Mauro Pintus
« Reply #4747 on: May 14, 2018, 08:40:48 pm »
I just tried the latest 791 build.
The files inside the mega328_st7565_kit folder works fine without any change on my tester (same as your picture).
Mauro
« Reply #4748 on: May 14, 2018, 09:48:18 pm »
You're right. I must have gotten some files mixed up, but it works now. Thanks for confirming.
Do you know how to enable the protection relay in the firmware? I didn't find anything in the documentation.
Offline madires
« Reply #4749 on: May 15, 2018, 10:42:49 am »
You don't need to enable anything in the k-firmware for using the protection relay. It's part of the basic code.
