Hi turbochris, glad you was able to fix your unit that easily
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Now that upgrading the firmware is a piece of cake, you can consider also the m-firmware to play with.
As you might know there are 2 main developments/developers of the firmware:
k-firmware manteined by karl-heinz kubblerer (this is the firmware you loaded on your unit)
m-firmware manteined by Markus Reschke (madires here in the forum)
Both great firmwares and great guys!!!
For the k-firmware, there are available the precompiled files for most of the hardware out there and the official folder is here:
https://www.mikrocontroller.net/svnbrowser/transistortester/Software/trunk/The fish8840 is present, but for the 16MHz you need to compile it changing the parameter in the Makefile (or someone will provide it to you...)
The m-firmware need to be compiled from source, but for the most common hardwares you can find the compiled files in the forum.
The m-firmware official folder is here:
https://www.mikrocontroller.net/svnbrowser/transistortester/Software/Markus/The current version is the 1.29m
Thank you for your interest in my YouTube channel!!! I'm doing my best to be more active
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I've watched some of your videos, are you a drag racer?
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
Mauro
