I'm trying to do a detailed breakdown of ALL ATmega328 Transistor Tester Options from the minimum system to the full bells and whistles version. Does the following list look correct so far?
Absolute Minimum System1.) 3× 680R resistors matched within 0.1%
2.) 3× 470k resistors matched within 0.1%
3.) 2× 100nF Capacitors (AVCC & AREF to GND)
4.) 1× 10k Resistor (Reset Pin)
5.) ATmega8/88/168/328
6.) Your Choice of LCD + Supporting HW
7.) 0.1% scientific laboratory grade power supply w/5.000 volt output
8.) Push Button
NOTES:
Internal 8MHz Oscillator
Internal Atmega IC Vref
M A I N O P T I O N SInterfaceOption 1 minimum/requiredPush Button
Option 22× Push Buttons (Increase/Decrease)
Option 3Rotary Encoder
w/integrated push buttonOption 4Touch Screen (M-firmware Only as of 9/2017)External DC Supplied Vcc PowerOption 10.1% scientific laboratory grade precision power supply w/ 5.000 volt output
Option 25 Volt Regulator w/ better than 0.4% precision
Option 35 Volt Regulator + 0.1% Precision Voltage Reference IC
Battery Based Vcc PowerOption 1On/Off Switch + Test Button(s)
Option 2MCU Controlled Timed Shutoff w/ Supporting Hardware + Push Button
Battery Option A9 Volt Battery + LDO 5 Volt Regulator w/ better than 0.4% precision
Battery Option B9 Volt Battery + LDO 5 Volt Regulator + 0.1% Precision Voltage Reference
Battery Option C3.7v Lithium Battery + Boost Converter + LDO 5 Volt Regulator + 0.1% Precision Voltage Reference
Oscillator Option 1Internal 8MHz
Option 2External 8MHz Xtal
Option 3External 16MHz Xtal
Option 4 (
M-Firmware Only)
External 20MHz Xtal
Option 2-4AStandard oscillator Capacitors (~20pF)
Option 2-4B1× Standard oscillator Capacitor + 1× Trimmer Capacitor ~0-30pF (Requires Frequency Measurement Device w/ Precision Disciplined Reference Oscillator such as a Rubidium Osc or GPSDO)
LCD Variations ~HD44780 (16×2/Hitachi Character)
~ST7036 (Dog-M)
~PCF8812 (Nokia 3410)
~PCF8814 (Nokia 1100)
~PCD8544 (Nokia 3310/5110)
~SSD1306 (microscopic size-OLED)
~NT7108 (Graphic Mono)
~ST7565 (Graphic Mono)
~LCD2004 (20×4 Character)
~ST7735 (Graphic Color 🐌)
~ILI9341 (Graphic Color 🐌)
~ILI9342 (Graphic Color 🐌)
~ST7920 (Giant Graphic Mono)
Additional Auxiliary Features Options ~TVS Array/Relay Circuit Protection
~Frequency Output
~Voltage Measurement (0.1-50 Volts)
~Zener Threshold Testing
~Infrared Remote Frequency ID
~Xtal Measurement (K-firmware)
~Optocouple IC Tester
~PWM LCD Backlight (LM339 based)
~UART Serial Communication
~Solenoid Tester
~Direct External Frequency Measurement
~High/Low Freq. Measure w/Buffer&Prescaler
~Self Calibration Capacitor Circuit
~Sampling ADC Relay+Capacitor (K-FW Only)
Unofficial/None Supported Auxiliary Features ~Bluetooth Serial Communication
~LC Meter Circuit (LM311)
~LC Meter Circuit (ATtiny3213)
~Xtal Test Circuit (PIC16F628A)
The idea is to subdivide every extra circuit option on a schematic... you will see
With this level of breakdown I should be able to explain everything from the 328 version visually without language. Basically I'm creating an ikea instructions type version of the pdf.
Note: This list has been edited to account for all posts of mistakes and omissions after this one as of September 15 2017.
